Old 08-06-2021, 08:17 PM   #1
STAN WHITE
Default 1934 ford radiator side brackets location?
I need help in locating proper location on the radiator sides for the two OEM brackets. There are more than needed locations. Must be for different model configurations. I have a three window coupe. Thanks Stan
STAN WHITE is offline   Reply With Quote
Old 08-06-2021, 08:29 PM   #2
3quarter32
3quarter32's Avatar
Default Re: 1934 ford radiator side brackets location?
This help, maybe?
3quarter32 is offline   Reply With Quote
Old 08-07-2021, 03:11 AM   #3
deuce lover
deuce lover's Avatar
Exactly what brackets are you talking about? From the radiator to the grille? If so -no difference from 3W,5W,Sedan,Cabriolet Victoria,SD,roadster,phaeton etc. Pictures always help.
deuce lover is offline   Reply With Quote
Old 08-07-2021, 10:42 AM   #4
DavidG
DavidG's Avatar
Also, four or V8 as the brackets are different for each as is their location?
Old 08-07-2021, 10:46 AM   #5
deuce lover
I was going by V8 as I presume his car is a V8.
Old 08-07-2021, 11:44 AM   #6
STAN WHITE
Yes it is a v/8 The brackets I am asking about are the two on each side. One is for the Grill to inner fender panels. The other is for the front hood latch. I have tried to find a picture but have had no luck. Thanks Stan
Old 08-07-2021, 11:48 AM   #7
deuce lover
Here is a pic from the Green Bible.Hope it helps.Maybe DD or Trevor can enlarge it.Here is another pic I found showing the bracket installed.The inner fender panel is attached to the grill also.There is a pic in the 33-34 book that clearly shows the bracket.Also in that book there is a pic of the top bracket installled.Once you begin assembly it pretty straight forward.
