12-04-2021, 11:10 PM | #1 |
Head damage, possible causes?
This is the passenger side head off of the industrial engine I have. Severe damage on the casting, but absolutely no damage to the cylinder or the piston. Just trying to figure out what happened here?
A machinist friend of mine said it could’ve been a flaw in the casting, but I don’t see how it could’ve ran for years if it was a flaw. |
12-04-2021, 11:12 PM | #2 | |
Re: Head damage, possible causes?
12-04-2021, 11:14 PM | #3 |
Hydrolock?
12-04-2021, 11:26 PM | #4 |
12-04-2021, 11:43 PM | #5 |
Compression vs. head and compression won.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
12-04-2021, 11:51 PM | #6 |
12-05-2021, 12:15 AM | #7 |
Given the rust and crust in the rest of the engine it will need to come apart anyway. I would very carefully inspect the cylinder bore, rod, and piston for that hole.
12-05-2021, 07:18 AM | #8 |
I’ve seen that in old engines left out to the weather It broke at the weakest point, might have cylinder wall cracks as well.
12-05-2021, 08:47 AM | #9 |
Rust or weak casiting in combustion chamber or a combination and the compression finally caused it to give way.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
