Old 12-01-2021, 05:14 PM   #1
nkaminar
nkaminar's Avatar
Default Anyone running this supercharger
A friend sent this to me. His friend has ordered one. It looks like it could be modified to use a Weber.
https://frenzelsuperchargers.com/pro...hp_VaqImtdr5_A
File Type: jpg Screen Shot 2021-12-02 at 8.35.47 AM.jpg (15.1 KB, 762 views)
Old 12-01-2021, 06:19 PM   #2
Terry Burtz, Calif
Default Re: Anyone running this supercharger
Fred Roberts in Australia belongs to the Facebook group "The Burtz Ford Model A Engine", and posted the following: https://www.facebook.com/fred.robert...88338830182047
Terry Burtz, Calif is offline   Reply With Quote
Old 12-01-2021, 10:41 PM   #3
California Travieso
Send a message via Yahoo to California Travieso
Wow, all we need now is fuel injection!
David Serrano
California Travieso is offline   Reply With Quote
Old 12-02-2021, 12:58 AM   #4
Brad in Germany
Brad in Germany's Avatar
To keep it era correct, how about installing a "'Bat' Super-Charger" instead:
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 12-02-2021, 02:38 AM   #5
updraught
updraught's Avatar
The actual Frenzel is being made here in Oz in Queensland. I believe they hold the patents and all. They are making them for the early V8, but had a prototype Model A at Rattletrap this year (based on the Race of Gentlemen).
It seemed quick on the beach.
This is based, I'm told, from a supercharger made in the UK in the 1930's and 12 were built and 6 stolen. No more were made.
https://www.frenzelsupercharger.com/
updraught is offline   Reply With Quote
Old 12-02-2021, 01:20 PM   #6
Terry Burtz, Calif
The Model A superchargers are available from Aaron Loveless who lives in Prunedale, CA.
Aaron's phone number is 1 831 233-0787. His website is: https://frenzelsuperchargers.com/contact
I have a supercharger on order and will display it along with the "New Engine Kit", new flywheel, and new camshaft at the Turlock, CA swapmeet on January 29 and 30, 2022.
We will be in the building and across the aisle from the snack bar sharing a space with John Lavoy.
Old 12-02-2021, 08:48 PM   #7
AZ_Nick
I have one from Aaron but have not had a chance to run it yet. It's based on a small import blower and Aaron makes all the pieces for a bolt on installation with a Model A downdraft manifold.
AZ_Nick is offline   Reply With Quote
Old 09-29-2023, 09:48 PM   #8
imtb
Just finished installing super charger. Burt’s engine and T5 Very responsive, still tuning. More to come.Fits under hood.
File Type: jpg 06AAF324-0380-449C-B030-718E7DDA169E.jpg (54.3 KB, 199 views)
imtb is offline   Reply With Quote
Old 09-30-2023, 05:05 PM   #9
NH-A
So what does what of these add for performance?
NH-A is offline   Reply With Quote
Old 09-30-2023, 05:22 PM   #10
Pete
Pete's Avatar
Looks very similar to the one used on the Crosley powered aircraft APU from WW2.
Old 09-30-2023, 06:06 PM   #11
Gene F
Gene F's Avatar
IMTB - wow. Hope you have improved the brakes on you car.
Old 09-30-2023, 07:36 PM   #12
Mountain Dew
Mountain Dew's Avatar
Here's my supercharger.
Mountain Dew is offline   Reply With Quote
Old 09-30-2023, 07:44 PM   #13
nkaminar
nkaminar's Avatar
A supercharger runs off the crankshaft and takes power to run. A turbocharger runs off the hot exhaust, heat that is normally thrown away. It does add some back pressure so it is not free. But in my opinion it is a better way to go.
So, does anyone out here run a turbocharger? A turbocharger designed for a small engine would work. Say an engine of 100 cubic inches that runs at 4,000 rpm or 50 cubic inches that runs at 8,000. Maybe a motorcycle engine.
Old 09-30-2023, 08:09 PM   #14
stickshift
stickshift's Avatar
I remember a few years ago people on the Ford Tractor forum I frequented were talking about using a "smog pump" like the ones from the 1970's to force air into the carburetor of their four cylinder tractors. They claimed it made a good improvement. Sort of a poor man's supercharger. Of course, any time you increase the air volume, the fuel volume would need to also be increased to maintain the 14.7:1 air/gas ratio. Lean conditions can be catastrophic.
Stickshift
1915 Model T touring
1931 Ford Model AA Flatbed
stickshift is offline   Reply With Quote
Old 10-03-2023, 11:39 PM   #15
Y-Blockhead
Y-Blockhead's Avatar
I saw this somewhere and I thought it was interesting enough to save the picture, but of course I can't remeber where.
Look familiar to anyone?
Old 10-04-2023, 06:51 AM   #16
Juggler
Juggler's Avatar
Not this one, but my buddy Jamie fitted a Wade RO34 to his Roadster
The head is a "GEM" one of six made in UK by Belcher Engineering
Wades are reasonably easy to get hold of in UK. The last one I bought was £100
https://youtu.be/zUhmFdwrAmk?si=O6qDUy9Hmc9bo_Ut
Juggler is offline   Reply With Quote
Old 10-04-2023, 07:07 AM   #17
nkaminar
nkaminar's Avatar
One thing to be aware of when fitting a supercharger or turbo charger to your engine is that it would benefit by a change to the cam timing, leaving the intake open longer.
Old 10-04-2023, 11:36 PM   #18
Herb Concord Ca
Years ago, H & H had a turbo charged A engine at Turlock swap meet.
Herb Concord Ca is offline   Reply With Quote
Old 10-05-2023, 11:40 AM   #19
stevemclark
stevemclark's Avatar
Did it do more than take your money?
It's not the destination ,it's the journey .
stevemclark is offline   Reply With Quote
Old 10-10-2023, 08:28 AM   #20
imtb
Here is a couple pics of the Loveless Super charger I installed. I had the burns intake but was going to fit under the hood. I bought a weber intake from Mikes afforable A's (ha ha afforable). I have to weld up the weber bolt pattern and drill the Stromberg 97 bolt pattern. I just used a gasket to transfer punch pattern. Everything bolted right up. I just used one slot on the support bracket and there is a bolt hole under the snout. I bought about 6 belts to find the correct length and ended up with B-55, I bought a B-54 also for a backup.
Linkage was next, I had one Burns linkage and thought, bolt 2 of them together might work. It works pedal is kind of hard, i still need to fiddle with it.
I am running a burtz engine, touring cam and high compression head. It fires right up and drives like normal but when you get into it keeps pulling and with the T5 keeping up with traffic is easy.
Really happy with the end results and pretty easy install and looks good.
