Old 12-05-2021, 08:15 AM   #1
chrs1961815
chrs1961815's Avatar
Default Battery Carrier Removal
I was wondering how to take the battery carrier out of the car on my 27 Coupe? I am not sure if it is damaged or not - looks like someone welded sheet metal sides to it to create a box.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 12-05-2021, 10:35 AM   #2
stevests
stevests's Avatar
Default Re: Battery Carrier Removal
Should be 3 bolts - 2 on one side & 1 on the muffler side. One bolt should be the ground strap connection - the remnants of sheet metal don't appear to be what's left of an original Ford battery box.
stevests is offline   Reply With Quote
Old 12-05-2021, 02:07 PM   #3
chrs1961815
I have it loose but I can't figure out to get it out. It is in between the two frame rails and there is no space to pull it from the bottom or top. What am I missing?
Old 12-05-2021, 04:26 PM   #4
mercman from oz
mercman from oz's Avatar
Battery Carrier looking a bit worse for wear.
Old 12-05-2021, 05:56 PM   #5
stevests
stevests's Avatar
If you have all three bolts out, you should be able to manipulate (muscle) it out.
