04-24-2018, 06:51 AM | #1 |
1939 Key
When I purchased my 39 it had one key and that was in the ignition lock. Were there separate keys for the door or the trunk or should that one key work each lock? Thanks guys!
04-24-2018, 07:22 AM | #2 |
Re: 1939 Key
Ignition key and door locks should be keyed alike. Trunk and glove box are keyed alike. Does the ignition key you have not work the door locks?
04-24-2018, 07:54 AM | #3 |
Re: 1939 Key
On my '41 I pulled the door lock and gave the numbers to 32Phil on this forum, I had him make me a set, worked great in my ignition, and door. I had previously had an ignition key cut from original at a locksmith, it didn't work as well as Phils.
04-24-2018, 08:23 AM | #4 |
Re: 1939 Key
On my 39 Std the Ign key and door, trunk keys are different.
04-24-2018, 08:29 AM | #5 |
Re: 1939 Key
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 |
