04-09-2018, 06:54 AM | #1 |
valve seat cutter
Does this look like equipment for Ford v8's?
"whatever works!" |
04-09-2018, 07:12 AM | #2 |
Re: valve seat cutter
Picture does not show everything but it could probably grind seats in a flathead.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
04-09-2018, 07:25 AM | #3 |
Looks like a Sioux setup for installing valve seats.
Its for cutting the pocket you drive the valve seat into. Could be another brand but some of the cutters are atleast Sioux style. |
04-09-2018, 02:02 PM | #4 |
I could use something that can grind seats, not sure about this.
"whatever works!" |
04-09-2018, 02:07 PM | #5 |
Thats a slow moving unit if i´m right and not suitable for grinding hard seats.
But a nice setup for installing seats they usually don´t have the power unit just a ratchet. |
04-09-2018, 06:51 PM | #6 |
04-09-2018, 06:54 PM | #7 |
I think I'd leave installing seats to a machinist. OK, I'll pass on this one.
"whatever works!" |
04-16-2018, 10:57 AM | #8 |
How about something like this?
https://www.ebay.com/p/5-Pcs-Valve-S...6045375&chn=ps
"whatever works!" |
04-16-2018, 11:14 AM | #9 |
Paper weight no pilots.
R |
04-16-2018, 12:05 PM | #10 |
The eBay listing says "two guides". I would have to think those are actually the pilots. If not, please enlighten me.
04-16-2018, 12:50 PM | #11 |
They may be pilots but it is still a paperweight as they won't work on a flathead.
A Flathead needs a special size pilot(1 1/32") In fact it doesn't say what size they are at all. That system is under 40.00 you won't get much that will help with a flathead. For someone to buy that with the thought of doing up a flathead is in for a steep learning curve if is his first attempt.Step up and buy a neway system. The cost of a neway start up system isn't cheap. That is my 2¢. R |
04-16-2018, 01:31 PM | #12 |
Yes, the guides are pilots. 5/16 and 11/32. 11/32 is very close to the valve stem diameter, I measure .341 on my (used) valves. I have a lathe and could modify if needed. Add says won't work on "modern" hardened seats. My engine has seats on all valves, will these cutters work on them?
"whatever works!" |
04-16-2018, 01:42 PM | #13 | |
"whatever works!" |
04-16-2018, 01:45 PM | #14 |
Only "blade" cutters that work good on hardseats are the neways and they have special inserts for it.
Find an old stone setup, the old black & decker setups had the plathead pilots in the kits. Does a job as nice as any modern machine just takes a bit more time. |
04-16-2018, 02:23 PM | #15 |
There's a carbide cutter just like that that works great . The pilots are ' made of steel and center cut on each end to be turned to size . So you need to find a guy with a lathe or open up a sacrificial guide to one of the pilot size you get . Just use the guide as part of the tool .
A bit more work but ,,, |
04-16-2018, 02:28 PM | #16 |
I just cut some harden seats on a 35 21 stud , make that a 36 . I have an old souix and used the pink stones that are marked for stellite.
I bought the eBay kit cause I could not find the Sioux, Dah , as soon as the new kit came I went to cut some valve on the valve grinder and stepped on the darn box I've been looking for . It was red and I would have sworn it was dark blue . |
04-16-2018, 02:31 PM | #17 | |
If he doesn't have the dresser , I do . If you need them dressed I'll do it for you . Just $ shipping . |
04-16-2018, 02:45 PM | #18 | |
B & D are .375 pilot size so is blue point snap-on and neway...and some i´ve probably forgot. Sioux are .385 pilot size And the stone thread is smaller on B & D. |
04-16-2018, 02:58 PM | #19 |
I know he doesn't have the dresser, but I thought I'd buy a new set of stones for him for the use of the tool. Thanks for the offer, once I get my hands on it I'll know what it will take to make it usable.
"whatever works!" |
04-16-2018, 03:56 PM | #20 |
I have both setups , the black and decker is a bit heavier , so the Sioux gets the workout .
Offer is still good . |
