03-04-2022, 09:28 AM | #21 | |
Re: Ignition for 8BA
I wonder if Charlie can convert the corvette ones with the side tach drive? |
03-05-2022, 06:52 AM | #22 |
Yes, Charlie can do tach drive Chevy's and Mallory's. Cast iron distributors...'57 to
early '60's are no problem either. Charlie ny |
03-05-2022, 12:10 PM | #23 | |
Before GM obsoleted them, when I worked outside sales as a District Sales Manager for Delco I sold a ton of those tach drive housings to a local guy for boat and RV use. Those are pretty cool. |
03-05-2022, 12:16 PM | #24 | |
03-06-2022, 08:33 AM | #25 | |
When I switched to a 4GC carb converting to a Chevrolet distributer with an electronic pickup made more sense than stick with points and unreliable or mismatched coils and ballast resisters. My curve; 18* @ 1800 rpm total 22* @ 2400. 70mph @ 2650 rpm 12* @ 14" of vacuum. using manifold vac. That's about 2" under highway cruise vac @ 60mph. Much of this curve was gleaned from the posts (here) of Bubba's ignition when he was racing and building distributers. (thankx Bubba, you were spot on). |
03-06-2022, 08:46 AM | #26 |
03-06-2022, 04:43 PM | #27 | |
The one in my truck Is the same design but long after Jacobs & Clifford parted company. |
03-06-2022, 05:20 PM | #28 | |
The Corvette & Chevrolet passenger cars began offering "RPO K66" TI (Transister Ignition) during the 1964 production year. BUT....Pontiac initially offered it for their 1963 production year. DD . |
03-06-2022, 05:59 PM | #29 |
In my youth we always looked for the cast iron ones as they supposedly had a better advance curve. True or not I have no idea, but I'll bet Charlie would know...fact or fiction
03-06-2022, 07:13 PM | #30 |
What coil should go with Charlie's distributor, for either the 6 or 12 volt system?
Steve in Denver |
03-06-2022, 10:07 PM | #31 |
NAPA IC 7 6v.........NAPA IC 14 12v both internal resistor
Charlie ny |
03-07-2022, 12:52 AM | #32 |
Charlie, no comment on the cast iron dizzys?
03-07-2022, 10:37 AM | #33 |
Bubba used to recommend the 012 Bosch Blue Coil . Internal resistance.
Making the simple complicated for over 30 years. |
03-07-2022, 01:22 PM | #34 |
I have been using an old 6v Mallory's Best. It' a heavy duty.
