Old 09-08-2011, 09:46 PM   #1
eagle
eagle's Avatar
Default T wire wheels
I found two wire wheels that I at first thought were for a Model A but they are different.... center hub is about 9 inches diameter by maybe 1 1/4 inches width (of hub) has 21" tires on them. Seems to have a larger bead roll than an A wheel too. Could they be T wire wheels? If so, what are they worth? They are nice and straight, no bent spokes etc.
eagle is offline   Reply With Quote
Old 09-09-2011, 08:19 AM   #2
tmodelman
tmodelman's Avatar
Default Re: T wire wheels
Model T 21" wire wheels have 5" bolt circle.
The wheel hub drum is approx 9" in dia. The hub cap opening is approx 2 1/2" dia. The tapered looking 'Dixie cup' like shape of the center of the hub is the best way to identify quickly.
tmodelman is offline   Reply With Quote
Old 09-09-2011, 08:22 AM   #3
tmodelman
tmodelman's Avatar
To add....if T wire wheel, and in good shape, not rusted or pitted value is between $50 and $100 ea.
Old 09-09-2011, 09:21 AM   #4
t42
Definately could be T wheels. 9 inch hub is correct. Were you looking for A wheels?
I have five 9 inch T wheels, but the hub-cap opening is 2-3/4 inch instead of 2-1/2 inch, so I can't use standard wire wheel hub-caps for 26/27 wire wheels. $50 to $100 sounds pretty reasonable.
t42 is offline   Reply With Quote
Old 09-22-2011, 12:35 AM   #5
'29wagon
yes , we discussed this about a year ago, those without the raised area between the stud holes are in fact the notorious "AR" wheels . as things were changing over from "T" to "A" .
i sold a set for the same reason. they did not fit my 1929 .
the lug pattern= five on four and seven eights inches. the hub hole is too tight for a '28/'29 front fit.
good for a '26/'27.
very deceiving.
'29wagon is offline   Reply With Quote
