09-01-2011, 09:37 AM | #1 |
Generator Regulator
My daily driver 29 Fordor charged fine (about 18 amps continuously, checked with a modern digital meter) but I was worried about overcharging the battery so yesterday installed a regulator from Mac's. It is encased in the original looking cutout package so looks completely stock. The directions said to adjust to a maximum of 15 amps via the 3rd brush before installing the regulator. When I tried to adjust the 3rd brush it was very hard to get it to 15 amps. A 1/8 inch adjustment takes it from 6 amps to 18 amps. I finally got it to about 14.5. After putting the regulator on, it charges really nice, about 10-12 amps when its first started then tapers off to about 3-4 amps within a couple of minutes. However, when running the light on it won't keep up. Has a negative reading of about 5 amps. I run the 50/32 CP (??? think thats right??) bulbs. The car is truly a daily driver, I use it every day unless the weather is bad so need lights. If I turn the 3rd brush back up to 18 amps I worry about the regulator and the generator.... any advice?
09-01-2011, 09:53 AM | #2 |
Re: Generator Regulator
i used to have as much as a 18A charge rate to get bright 50cp bulbs, then I put in the direct fit halogen bulbs (from classicandvintagebulbs much better than 50cp)--then at 14-15A I could have a 1A charge with the headlights on 18A is a little much for the gen to have the longest life, any weakness in the insulation, connections, windings etc. and there will be a massive failure ---I would run with the cover off to help it cool |
