Old 08-15-2020, 07:12 PM   #1
sofield
Default Alternator over charges
Alternator puts out 20 amps with a full charged battery. What's the cause
sofield is offline   Reply With Quote
Old 08-15-2020, 08:22 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Alternator over charges
Loose connections somewhere, maybe faulty regulator. Bad battery.
Old 08-15-2020, 10:39 PM   #3
eagle
eagle's Avatar
You need to do a voltage check in order to help us troubleshoot the issue. Do the check directly on the battery and another right at the alternator. Get back with the data.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 08-16-2020, 08:52 AM   #4
Patrick L.
Patrick L.'s Avatar
Does it have the 'D' slot to bypass the regulator ? If so, do it and see if the charge rate changes. That is I'm assuming yours has an internal regulator. If it has an external one then bypass it and take a look.
Old 08-16-2020, 08:54 AM   #5
Badpuppy
Check ground between alt and battery post.
Badpuppy is offline   Reply With Quote
Old 08-16-2020, 11:09 AM   #6
rotorwrench
rotorwrench's Avatar
As mentioned, always check all the wires and connections first. A high resistance connection is a load just like a resistor so it will get hot and draw unnecessary current. The battery should be load tested, charged, and serviced unless it is a non service type. In any case it should maintain rated voltage well after charging.
If everything checks OK then it's time to think about an alternator repair or replacement. The solid state internal alternator controllers should keep voltage right on spec and current should be minimal after the battery is changed back up from starting the engine.
Old 08-16-2020, 11:30 AM   #7
Marshall V. Daut
Check your "Private Messages" in the top right corner of this webpage.
Marshall
Old 08-16-2020, 12:17 PM   #8
Tom Endy
Tom Endy's Avatar
My suggestion is to clean the connection where the battery ground cable attaches to the frame. It is out of sight and hard to access. It is the most neglected electrical connection on a Model A.
Tom Endy
Tom Endy is offline   Reply With Quote
