06-07-2020, 02:35 PM | #1 |
Can I Safely Open Spider at Steering Column
Can I just move the spring clip and the bottom of the spider opens or will "stuff" fall out and get loose. I'd like to clean in there, but if it ain't broke don't fix it" may apply.
06-07-2020, 03:11 PM | #2 |
Re: Can I Safely Open Spider at Steering Column
Yes nothing will fall out,slight turn to remove. if working fine leave it.
www.whidbeymodelaclub.com |
06-07-2020, 03:45 PM | #3 |
They are easy to get off but hard to get back on. My wife had to help me with this and now I owe her big. Also, some of the clips that the vendors are selling need modification to fit.
06-07-2020, 04:10 PM | #4 |
Like almost everything else they sell, eh?
The Master Cylinder Enjoying life at the beach in SoCal... |
06-07-2020, 07:43 PM | #5 |
IF IT AIN'T BROKE, DON'T FIX IT. Henry Ford...
06-07-2020, 09:05 PM | #6 |
06-07-2020, 10:29 PM | #7 |
I'd remove cover and look, no spray, easy to do! Or maybe try some electrical spray cleaner, never tried that but might work. You can do it!!!
06-08-2020, 05:41 AM | #8 |
Nothing can happen, very simple. Courage!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
06-08-2020, 07:59 AM | #9 |
Disconnect the battery. That yellow wire is hot.
