Old 08-26-2017, 03:02 PM   #1
ursus
Default Tie Rod and Drag Link Seal Caps
The metal tie rod/drag link seal caps that I got from Bratton's have a 0.990 inch hole so they won't fit over the 1 inch balls. Am I missing something here? Maybe I have to grind the holes larger. The are actually one of those Ford Motor approved replacement parts.
ursus is offline   Reply With Quote
Old 08-26-2017, 04:03 PM   #2
SoCal_Alden
SoCal_Alden's Avatar
Default Re: Tie Rod and Drag Link Seal Caps
I just went thru the steering on my truck and yes, the seal cap IDs are too small. Dan and Jeff @ Snyders know about this and are having their supplier open up the hole on their next production run. In the meantime, I chucked a 7/8 drum sanding bit into my drill press and opened up the new seal caps until they fit over the steering balls and also seated onto the shoulder below the ball.
I also noticed that their new pitman arm was too thick ( ~0.025") on the back side and didn't want to seat properly onto the steering sector gear - the bolt wouldn't fit thru the notch. After taking the excess material off the pitman arm the bolt slide in perfectly.
When reassembling, I followed previous advice here on the fbarn and removed the steering arms from the perches, assembled with the EZ steer Teflon ball cups & new springs, and adjusted/greased prior to re-installing on the truck - made life a whole lot easier, plus I found that the original steering arm castellated nut threads were shot - so new nuts were also used.
Very satisfied with the results - SO much easier to steer + removed the excessive ~ 4 inch play at the steering wheel !!
Cheers,
SoCal_Alden is offline   Reply With Quote
