10-15-2020, 07:05 PM | #1 |
Aftermarket radiator cap.
I buy a radiator some time ago at a swamp meet and the cap is not the standard one. It was made in USA and the threads are 2 1/2 in diameter.
Someone can tell me if a cap is available? Regards. |
10-15-2020, 07:06 PM | #2 |
Re: Aftermarket radiator cap.
10-15-2020, 07:43 PM | #3 |
is that a Model A radiator ?
10-15-2020, 08:01 PM | #4 |
Your cap is the right diameter, but that radiator neck doesn’t appear to be a Model A. A photo of the cap would help to determine if it resembles a Model A cap, and another picture of the neck with the cap as it sits (or doesn’t) in relation to the neck.
10-15-2020, 08:04 PM | #5 |
That's been modified. Model A caps are not threaded. At least my '31 is not.
10-15-2020, 08:10 PM | #6 |
10-15-2020, 09:41 PM | #7 |
Looks like an aftermarket aluminum radiator.
10-16-2020, 10:19 AM | #8 |
Forgot to say, it's an aftermarket radiator i need a 28-29 cap. I have few old radiator who are not threaded. Thanks.
10-17-2020, 12:20 PM | #9 |
Sell it at another swap meet.
10-17-2020, 01:57 PM | #10 |
10-18-2020, 10:23 AM | #11 |
Threaded radiator necks are available from some model A parts vendors .. Care must be taken if installing a radiator neck or the radiator shell won't fit .
10-18-2020, 12:19 PM | #12 |
My radiator is a 28-29, and it is threaded
10-18-2020, 02:37 PM | #13 |
The 1930 pick up and AA trucks up to June 1930 used a 28-29 style radiator with the later style tabbed cap .
10-18-2020, 03:17 PM | #14 |
I believe the original 28-29 radiator cap threads are 2 3/16 inch. If the cap you have is indeed 2 1/2 inch, it's not correct for an A.
