Old 06-18-2020, 10:26 AM   #1
Dean Lemoine
Dean Lemoine's Avatar
Default Disconnect switch
Does anyone have pictures of a disconnect switch mounted under the front seat?
I can’t figure out a good way to run the cables. Thanks in advance for any responses
Dean Lemoine is offline   Reply With Quote
Old 06-18-2020, 11:03 AM   #2
katy
katy's Avatar
Default Re: Disconnect switch
Coupe? Sedan? CCPU? Other?
Old 06-18-2020, 11:34 AM   #3
Dennisfly
Dennisfly's Avatar
This is a picture looking down on the left front corner of the seat mount area on a 29 Town Sedan. The cable runs up through a hole in the floor pan and is installed in the positive ground cable. The handle is just above floor level at the front of the seat mount. I don't have access to take a better picture for a few days.
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 06-18-2020, 12:52 PM   #4
DNLs1930
DNLs1930's Avatar
My 1930 coupe has the disconnect mounted up through a hole on the left crossmember and the cables are routed through the hole for the brake rod.
I will add a few pictures later to show the exact locations of the routing.
DNLs1930 is offline   Reply With Quote
Old 06-18-2020, 04:44 PM   #5
Dean Lemoine
Sorry, It’s a 29 Tudor, my bad.
Old 06-19-2020, 06:39 AM   #6
Bruce of MN
Bruce of MN's Avatar
This is my '31 Coupe:
Old 06-19-2020, 09:20 AM   #7
Y-Blockhead
Y-Blockhead's Avatar
I have a similar switch as Bruce of MN but mounted from the bottom in my '30 Town Sedan.
Old 06-20-2020, 02:55 PM   #8
Dean Lemoine
Thanks for the responses, the pics are a great help. But, I’m going to hijack my own thread here though. The instructions that came with my switch say not to turn the disconnect switch off before stopping the engine if it’s an alternator equipped vehicle (mine is), due to “possibly causing alternator diode failure.” I’m also installing a safety fuse at the starter. Question: If the fuse blows while the car is running, wouldn’t that have the same affect as turning the disconnect switch off? I’m making my car 12 Volt negative ground with an alternator.
Old 06-28-2020, 01:20 AM   #9
Floats
Floats's Avatar
Hi Dean,
Some serious points to think about,
1. NEVER EVER admit or suggest that you want to, or have gone to 12v, positive, negative or whatever, NEVER EVER. You will never hear the end of it. I own a 12 volt negative Model A pickup as well as a 29 Chevy and I get it from both forums
2. Seriously now, I believe you are correct, it would be the same as turning off the disconnect which. However, fuses don’t normally blow and I believe, if they do, most probably on start up and only once in a blue moon. Get yourself a little mental checklist, ie, Fuel off, ign off, master off, etc
3. Alternator?(tongue in cheek again) GOTO point nr 1 and never mention it again. In fact, I am seriously considering changing my 250SL Pagoda and my E Type to 6v and generator. Maybe even the 911
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 06-28-2020, 07:04 AM   #10
Dean Lemoine
Floats: That’s a great response, I love it. Thanks for enlightening me as how criminal it is to convert to a 12 Volt negative ground. I had no idea. I promise never to let it be known again. I won’t let anyone ever look under the hood and if somebody asks about it, I’ll avoid the question or lie if need be.
Old 06-28-2020, 08:31 AM   #11
Patrick L.
Patrick L.'s Avatar
Originally Posted by dean lemoine View Post
floats: That’s a great response, i love it. Thanks for enlightening me as how criminal it is to convert to a 12 volt negative ground. I had no idea. I promise never to let it be known that again. I won’t let anyone ever look under the hood and if somebody asks about it, i’ll avoid the question or lie if need be.
:d:d:d:d:d:d
Old 06-28-2020, 02:02 PM   #12
Floats
Floats's Avatar
Smile Re: Disconnect switch
Great Dean, we are on the same page. Don’t let me down.
Cheers
Chris
Regards
Chris
Cape Town
Old 06-28-2020, 06:46 PM   #13
California Travieso
Send a message via Yahoo to California Travieso
Dean,
I don’t think anyone can tell you have a 12 volt system by looking under the hood. Even if you’re running an alternator It won’t give your secret away because many people run 6 volt alternators. The only way to tell is by looking at the battery which is safely tucked away under the floor board.
David Serrano
California Travieso is offline   Reply With Quote
