06-19-2020, 10:11 PM | #21 |
Re: best way to adjust valves
06-19-2020, 10:38 PM | #22 | |
06-20-2020, 04:04 AM | #23 | |
Not trying to be a clever clogs, but I think you made an incorrect assumption. Not being able to turn the motor by hand is a disadvantage. Mart. |
06-21-2020, 02:13 AM | #24 |
Tim, if you have the time, I'd really like to see that tool.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
06-21-2020, 02:27 AM | #25 | |
Mart, I get the cylinder at a time. It's clear as mud. Best to do one at a time I'm guessing. |
06-21-2020, 07:13 AM | #26 |
06-21-2020, 01:24 PM | #27 |
Thank you, very much.
06-21-2020, 01:59 PM | #28 |
Here's one from back in the day.. Acra cam.
06-21-2020, 10:01 PM | #29 |
Mine is a Lee Tool Co.
06-22-2020, 09:14 PM | #30 |
Somebody should write a book on how to adjust valves the easiest way. Only problem with that is the book would be as thick as the King James dictionary and 90% of the info would be wrong. The key word here is “EASIEST”. In this case, the easiest is also foolproof.
Here is another way to do it. Turn the engine until #1 exhaust is 20% open, then adjust #3 exhaust. Turn engine till #8 intake is open 10%, then adjust the #6 exhaust. Turn engine till #2 exhaust is open 50%, then adjust the fuel pump lobe. Follow this pattern til all valves are fubar and then stop and have a beer while you contemplate this joke. |
06-22-2020, 09:28 PM | #31 |
I have always done the exhaust just opening do intake.. Intake just closing do exhaust method. Been doing it that way all my life.
Tommy |
06-22-2020, 09:38 PM | #32 |
06-22-2020, 10:33 PM | #33 | |
06-23-2020, 08:34 AM | #34 | |
06-23-2020, 09:46 AM | #35 |
I like Pete's method, seems the most straight forward.
06-23-2020, 12:22 PM | #36 |
Any one who does not like my method does not have to use it. I found this method to be fast and foolproof FOR ME. I posted the method as one way to adjust valves. I DISCOVERED THE METHOD BY ACCIDENT
Yes I could dismantle motor and maybe get a more perfect valve adjustment. I do say MAYBE. This forum is to inform and (for me ) to get a lot of ways to do certain automotive things. This forum most of the time works for me. THANKS TO THE PEOPLE WHO RESPOND TO IT. |
06-23-2020, 04:08 PM | #37 | |
06-23-2020, 06:02 PM | #38 | |
Have you tried my method ? How do you find TDC ? How do you turn motor 90 degrees ? |
06-23-2020, 08:33 PM | #39 |
No, I haven't. But I'm not much interested in any of these so-called short-cuts. I adjust/check the lifters on all of the engines I work on with the lifter on the heel of the lobe. I start with a degree wheel and check the cam timing. You need a TDC marking and pointer to start with. It seems the easiest and most accurate to me. But, if you like your method, use it.
06-24-2020, 03:40 AM | #40 | |
Surely, if you've gone to the trouble and expense of installing adjustable lifters, you took the time to find TDC on #1, and marked the pulley as such WITH pointer. Bump engine over gingerly with starter to get each cylinder close, then 'rock' it in 3rd gear to sneak each 90 degree movement up to the money mark. Easy peasy! DD |
