04-22-2020, 01:30 PM | #1 |
Rear Motor Mount Bolts
Just sorting out some bolts to install the rear motor mount to the flywheel housing . I have some that would do but are cross drilled for a lock wire and some plain.
Originally were they lock wired or with a lock washer . Just curious . John in lovely locked down Spring Weather Suffolk County England . |
04-22-2020, 01:50 PM | #2 |
Re: Rear Motor Mount Bolts
Originals where drilled to accept cotter (split ) pins.
Quite nice here too in Nassau County, along side Suffolk County, USA jb |
04-22-2020, 02:05 PM | #3 |
Per RG/JS, Sec 1-9,
"The heads of the bolts were safety wired in various ways with 18 gauge plain or raven finished wire." No mention of lock washers.... TallyHo |
04-22-2020, 02:08 PM | #4 |
Ooops, Should have typed:
Section 1-5 Revised 2011 |
04-22-2020, 02:23 PM | #5 |
The rear engine mounts were bolted to flywheel housing with unfinished bolts AND lock washers and wired with 18 gauge wire which was plain or raven.
04-22-2020, 02:28 PM | #6 | |
Research the following; A-21207 Bolt - housing to rear engine support. A-22330 Lock Washer A-6402 Wire - engine support to flywheel housing support wire. . |
04-22-2020, 05:36 PM | #7 |
The above are correct......why did I read but think of the smaller motor mount to frame bolts???
Week 6 'Interment Camp Cuomo'......... |
04-23-2020, 03:41 AM | #8 |
Thank you all very much all is crystal clear . All my cars have lock washers and oddly enough not had any with wire . None are original so many motor changes over the years .
John in yet another glorious Spring Day we are heading for the warmest April on record and no Model A !!! Suffolk County England . |
