Old 09-21-2019, 07:34 PM   #1
Henry Floored
Henry Floored's Avatar
Default Unusual carburation on Flathead V8’s
Hey gang it might be fun to talk about and share pictures of unusual carburetor choices on Flathead Ford engines. I’m really talking about anything other than the normal 3 bolt 94 Holley/Fords and Stromberg 97’s.
I’ve looked on several occasions at some Italian “Vee” engine’s with their Weber and Del’Orto carbs and thought hmmmm???
Carbs like those ^^^ are often designed for 60 degree V6’s and V12’s which have narrow intake manifolding like our Fords.
So I’m curious if any of you have strayed from the beaten path. I’ll bet there’s a few that have used a Rochester 2GC, another good one.
What about Autolite 2100’s and 4100’s that came on small Ford V8’s in the 60’s.
Let it rip fellas if you have anything to say about this. Very interested to hear what you’ve done or plan to do in the future.
Thanks!
Henry Floored is offline   Reply With Quote
Old 09-21-2019, 07:39 PM   #2
Tim Ayers
Default Re: Unusual carburation on Flathead V8’s
I've seen one barrel Marvels with a Stromberg/Holley type base. Someone told me they were replacements. Same CFM, just one large single throat vs. two if I recall correctly.
I also think there were some 3 bolt Strombergs that had "L" backdraft horn that were used on Studebaker's of some sort. I could be wrong on this.
Old 09-21-2019, 07:46 PM   #3
tubman
tubman's Avatar
This is probably not what you wanted to see, but here are some pictures of my attempt to put a Quadrajet on a flathead. I figure if the would run on a 3.8 liter Buick, they could be made to work on a 3.9 liter flathead. I only had a couple of junk Quadrajets, and I couldn't get it to run worth a shit. I have a bunch of other stuff going on, so I abandoned the project.
I do plan to get back on it some day.
Old 09-21-2019, 07:48 PM   #4
paul2748
paul2748's Avatar
Probably should have used an adapter that had 4 holes in it, not the open one.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-21-2019, 07:54 PM   #5
petehoovie
petehoovie's Avatar
Old 09-21-2019, 07:56 PM   #6
tubman
tubman's Avatar
You're probably right. I had a bunch of parts laying around and I thought I'd try it. I had zero dollars in the attempt.
Old 09-21-2019, 08:05 PM   #7
petehoovie
petehoovie's Avatar
Old 09-21-2019, 08:30 PM   #8
Tim Ayers
Mike Davidson from Austrialia use to offer a dual or single quad set up. The base used tops from Offy OHV V8 manifolds.
Old 09-21-2019, 08:39 PM   #9
RalphG
RalphG's Avatar
I saw this one at a car show a few years ago. Looks like a quadrajet on it. I never heard it run but pretty sure he drove it to the show.
RalphG is offline   Reply With Quote
Old 09-21-2019, 09:07 PM   #10
tubman
tubman's Avatar
I can't see it very clearly, but I think that's a 4G.
Old 09-21-2019, 09:32 PM   #11
Henry Floored
Au contraire Tubman that is a very interesting project. I hope you get a chance to try it again.
Old 09-21-2019, 10:09 PM   #12
51504bat
51504bat's Avatar
JMO but a quadrajet on a flathead is just plain wrong.
Old 09-21-2019, 10:55 PM   #13
petehoovie
petehoovie's Avatar
Old 09-22-2019, 12:41 AM   #14
40 Deluxe
Can't be wrong if it runs right! A Q-jet from a 3.8 Buick etc. should be jetted right ,or at least close, and the small primary throttle bores are ideal. Those huge secondaries have an adjustable air valve above the throttle plates so no danger of over-carburetion. Just find or make a good flowing adapter and you're good to go with a little tuning (which you should do with any carb).
Old 09-22-2019, 12:43 AM   #15
19Fordy
19Fordy's Avatar
Not true, IMO.
Old 09-22-2019, 01:40 AM   #16
40 Deluxe
Originally Posted by 19Fordy View Post
Not true, IMO.
Good to see that a Holley equipped flatty owner also likes Q-jets!
Old 09-22-2019, 05:17 AM   #17
51 MERC-CT
51 MERC-CT's Avatar
Happy to be running a 4bbl. on my flathead, but even though it's a 4bbl. it is operated as 2bbl. carb. 99.9999% of the time, just as I suspect all the rest of the 4bbl. equipped flatheads are.
Old 09-22-2019, 05:36 AM   #18
Henry Floored
These are probably prohibitively expensive but dang they look like a perfect match to a Flathead Ford’s narrow intake manifold.
Old 09-22-2019, 08:11 AM   #19
Tim Ayers
I think Tony Baron made a Weber intake for flatheads at one time
Old 09-22-2019, 11:35 AM   #20
Russ/40
Russ/40's Avatar
My fantasies are more toward exotic, than performance. I've been thinking about running four updrafts.
