09-17-2020, 10:13 AM | #1 |
Coating the armature . . .
Any thoughts on what product would be suitable to coat the amature of a starter and/or generator (excluding the commutator of course). Polyurethane? Shellac?
Not a Purist. |
09-17-2020, 10:19 AM | #2 |
Re: Coating the amature . . .
Good question... i just ordered a can of
CRC Urethane Seal Coat Viscous Liquid Coating, Red hope this is the right stuff, it's identified in the Model A Generator book, says to soak in it but I ordered a spray can, Is this going to work or am I asking for Trouble |
09-17-2020, 11:09 AM | #3 |
Re: Coating the armature . . .
Should work fine.
09-17-2020, 01:06 PM | #4 |
Building transformers, dipped coil in Varnish and baked.
Bob F |
09-17-2020, 03:01 PM | #5 |
Glyptol, made by GE, used in the industry.
Buy at your local electrical supply store. Last edited by 42merc; 09-18-2020 at 06:15 AM. |
09-17-2020, 05:13 PM | #6 | |
Local Grainger stores generally have it too. |
09-17-2020, 05:59 PM | #7 |
Yes Glyptol. Have used for years on motor, alternator and starter repairs.
09-19-2020, 09:40 AM | #8 |
X4 on the Glyptol.
The power plant I worked at used Glyptol on EVERY motor, both exposed armature windings and the field coils. They claimed it prevented "working" of the wires under magnetic stress, and consequent wear-through of the varnish insulation. It is a bitch to get off for re-winding, however. By the time you get to that point you're talking a major rebuild anyway. It is also used a lot on the interior of cast iron motors/transmissions after tanking or blasting. Seals in the errant pieces of sand or grit and makes an interior surface the oil can "slip down on" easily. https://www.amazon.com/Glyptal-Brush...516BM8VVKG3WC7 Joe K
Shudda kept the horse. |
09-19-2020, 09:45 PM | #9 |
X5 on the Glyptol,
Have used it for a lot longer time than I would like to admit. The first time I used Glyptol was when I was working on Model A's to make a little money for collage. That was 66 years ago. Been using it every since. Chris W. |
