Old 03-21-2024, 10:25 AM   #1
Paragon
Default mounting EA Laboratory electric wiper
I just purchased an EA Laboratories electric wiper that functions perfectly. The wiper motor and mounting bracket are complete, but I want to set it up to work properly and know there are a lot of EA motors in use. The configuration of the mounting bracket is very similar to the Trico vacuum motor and the hole alignment is perfect. The fitting exiting the motor that engages with the wiper arm is a tapered spline with a nut and washer to hold it in place. I'm looking for pictures of an existing mount, the wiper arm that was used or modified, spacers between the bracket and the windshield frame and any other details you can provide. Thank you!
Paragon is offline   Reply With Quote
Old 03-21-2024, 01:31 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: mounting EA Laboratory electric wiper
I don't know if you have an open car or a closed one but check out this link. It has a lot of info. I hope it helps.
https://www.mafca.com/downloads/Semi...A%20Wipers.pdf
