07-07-2010, 01:16 PM | #1 |
Wiring diagram for alternator/VR setup
Hello:
Does anyone have a wiring diagram for a GM Delco-remy alternator setup with a voltage regulator separately mounted on the firewall? I have a 12V negative ground setup. There are two wires coming from the three connector pins (one unused) on the alternator and another wire connected to the + pole of the alternator. I am also looking to install an amp meter where appropriate in the circuit. Thanks, Mike Green |
07-08-2010, 11:57 PM | #2 |
Re: Wiring diagram for alternator/VR setup
