Old 11-09-2020, 03:16 PM   #1
wensum
wensum's Avatar
Default Nissan distributor for Model A
I have read that a Nissan electronic distributor with some modifications is a good installation on a modified Model A engine and wonder if anyone can tell me which model Nissan it would come from? (four plugs not eight)
wensum is offline   Reply With Quote
Old 11-09-2020, 04:04 PM   #2
Bob C
Default Re: Nissan distributor for Model A
Don't know about the Nissan but here is a link to a Honda distributor.
https://www.fordbarn.com/forum/showthread.php?t=244492
Old 11-09-2020, 04:35 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
And some Subaru
Old 11-10-2020, 12:48 PM   #4
Jim Brierley
I run a Mallory dual point built for a Datsun, later named Nissan. It takes some minor lathe work to make it fit the head, and a new drive shaft was needed, not a problem.
Old 11-10-2020, 03:25 PM   #5
McMimmcs
McMimmcs's Avatar
what is the advantage over an original distributor ?
Old 11-11-2020, 11:40 AM   #6
katy
katy's Avatar
Automatic advance.
Old 11-11-2020, 12:08 PM   #7
Jim Brierley
There are several advantages to a modern dist. Automatic advance is one, but they also have more dwell time (duration) which gives hotter spark, parts are available at many more places than Model A, are better designed and are generally not worn as much as an 85 year old unit.
Old 11-11-2020, 12:13 PM   #8
McMimmcs
McMimmcs's Avatar
[QUOTE=Jim Brierley;1950934]There are several advantages to a modern dist. Automatic advance is one, but they also have more dwell time (duration) which gives hotter spark, parts are available at many more places than Model A, are better designed and are generally not worn as much as an 85 year old unit.[/QUOTE
Both responses make good sense, thank you !
Old 11-11-2020, 12:17 PM   #9
Ruth
Especially with dual points!
Ruth
Old 11-11-2020, 12:18 PM   #10
Ruth
Ruth
