07-01-2020, 04:28 PM | #1 |
very early lugnuts on 28
What socket size are the lugnuts on a early 28. Mine are made like T lugnuts but slightly larger, between 11/16 and 3/4. I think it may be something in 64th or 32nds. Model T lugnuts are 21/32.
07-01-2020, 04:57 PM | #2 |
Re: very early lugnuts on 28
Resolved, 23/32nd or more commonly 18MM.
07-03-2020, 08:55 PM | #3 |
Interesting. I think I have some.
07-21-2020, 09:01 AM | #4 |
Let's bring this topic up again. Is there a difference between the T lug nut and the A lug nut on the early 1928's? I am showing a part number of A-21837 for the early style that eventually was changed to A-21837-AR when the A-21837-B Hub Bolt (Lug) Nut was introduced.
Seeing that it did have its' own A part number makes me believe it was different than the T hub bolt (lug) nut. Can anyone confirm and share the differences? |
07-21-2020, 08:44 PM | #5 |
Just as an aside, 23/32" apparently was a standard size nut. I encounter this size on occasion and have a couple of open end wrenches in that size. It's not truly 18mm as 23/32" converts to 18.3mm but that mm size will surly work.
Joe B |
07-21-2020, 09:57 PM | #6 | |
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
07-22-2020, 10:17 AM | #7 |
Thanks guys. I have lug nuts that are very similar but slight variations. I think out of 70 something lug nuts that I have, there are about four different variations in what I have. I wish I could get to see a print on these.
07-24-2020, 10:24 AM | #8 |
The Release for A-21837-AR says "Use T-2809".
The Drawing T-2809 shows a 11/16" diameter, height 1-1/8". |
07-25-2020, 12:06 PM | #9 |
11/16" diameter or AF?
