Old 03-27-2015, 11:38 AM   #1
Harylufa
Harylufa's Avatar
Default What is this carburetor car from?
Dear Friends!
I have this carburetor installed in a Ford V8 350, but someone told me that this is not the original one.
Can you help to identify this carburetor?
Thanks
Hary
I love my Ford V8 1946!
Harylufa!
Harylufa is offline   Reply With Quote
Old 03-27-2015, 11:52 AM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: What is this carburetor car from?
'49-ish Mercury flathead, I believe! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-27-2015, 12:08 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Also '49-'51 Lincoln or big Ford truck.
The one in the pic appears to have been converted to manual choke.
Old 03-27-2015, 12:10 PM   #4
Harylufa
Harylufa's Avatar
Hi all!
I really appreciate your help, this carb is installed in a Ford V8 350, called here Fase 2.
Do you know this engine?
Hary
Harylufa!
Old 03-27-2015, 12:23 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Sometimes also referred to as "towering infernos". DD
T5 W/TORQUE TUBE
Old 03-27-2015, 12:43 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
'52-'53 MERC'S were the towering infernos'
Old 03-27-2015, 01:10 PM   #7
rotorwrench
rotorwrench's Avatar
"Tea Pot" Holley 885. Trucks have the manual choke set up but a lot of them have governors. Early 1949 Mercs & Lincolns and a lot of trucks used a ball tip on the throttle arm and the later ones had the drilled hole for use of the clip retained type throttle rod. On the top of the accelerator pump relief, (the part that is the highest point on the top of the shroud) there should be the little numbers that are the date code for the carb. It will have the number of the month stamped next to a smaller raised cast in number that represents the last two digits of the year of manufacture.
Old 03-27-2015, 01:46 PM   #8
scooder
Originally Posted by Harylufa View Post
Hi all!
Hary
Put a pic of the engine on here, Ford 350 phase 2 means nothing to me. Ford 351, yes.
Martin.
scooder is offline   Reply With Quote
Old 03-27-2015, 01:50 PM   #9
scooder
The carb in the pic looks like the remains of a governor on the flange.
Martin.
Old 03-27-2015, 03:46 PM   #10
Ross F-1
Ross F-1's Avatar
Martin.
If you mean the arm at far bottom right, I think that is a truck-style manual throttle arm.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 03-27-2015, 03:58 PM   #11
scooder
Just had another look, think your right, does look like a hand throttle type of thing.
Thanks,
Martin.
Old 03-27-2015, 05:34 PM   #12
Harylufa
Harylufa's Avatar
Martin.
Hi!
I hace some pic from engine. Here we called Ford fase2. I need a manual how to assemble the engine.
Thank
Hary
Harylufa!
Old 03-27-2015, 05:39 PM   #13
Harylufa
Harylufa's Avatar
Rotorwrench!
I really appreciate this info, it is very valuable for me. It is the first time I see this kind of carburetor. Nowadays I am studyng in a course of Automotive mechanic.
Thank you very much
Hary
Harylufa!
Old 03-27-2015, 05:51 PM   #14
Mart
Mart's Avatar
I think the Argentinian fase 2 (phase 2) engines were a development based on the Y-Block. Not heard of a 350 though.
Mart.
Old 03-27-2015, 06:46 PM   #15
rotorwrench
I think the Ford 350 is like an F350 1-ton truck. The fase II heads have a more conventional split for the intake manifold and the exhaust was also improved but I believe it is still a 292 cubic inch motor.
Ford of Argentina used this motor for a lot longer than the USA and they improved it a lot too.
Old 03-27-2015, 07:07 PM   #16
Harylufa
Harylufa's Avatar
Hi!
This is my doubt, I thought that would be 292 cubic inch motor.
I need to find a manual from this engine.
Thanks
Hary
Harylufa!
Old 03-27-2015, 07:13 PM   #17
Harylufa
Harylufa's Avatar
Mart.
Mart!
What is the original carburetor from this engine?
Thanks
Harylufa!
Old 03-27-2015, 07:57 PM   #18
Tinker
Tinker's Avatar
So you putting a yblock in your 46? interesting setup. Always something different on these old fords.
I think those merc carbs are around 100 cfm. I think the early yblocks used a 94 Holley before moving to the teapot (tower of inferno) carbs. I put a 390 2 barrel on a 292 and it's been great. Just enough.
What's your plan?
Old 03-27-2015, 07:59 PM   #19
Tinker
Tinker's Avatar
Cool thread.
Some ques on the yblock which it looks like to me.
http://ford-y-block.com/Block%20identification.htm
Maybe the 350 nomenclature is based on the sbc Chevy craze. Or not.
Old 03-28-2015, 07:43 AM   #20
scooder
100 cfm? Gota be a typo?
Martin.
