Old 06-14-2021, 05:10 AM   #1
flatmotor40
flatmotor40's Avatar
Default stumbling then soomths out
Went for ride yesterday morning and the car cranked first hit and out of the garage we went,Got a mile or so and it started to stumble can run rough.and skip like it was running out of gas. Got to the store and started back home.Skipped and poped a little out of parking lot a mile down the road it finally smoothed out.Went on to ay Mom house.After a couple hours left for home ran like it used to fine.Crazy.Bad fuel filter or trash in carb Help need Thanks
flatmotor40 is offline   Reply With Quote
Old 06-14-2021, 05:24 AM   #2
flatmotor40
Default Re: stumbling then soomths out
Oh it is the 2nd time this happened.Thanks
Old 06-14-2021, 08:38 AM   #3
fordwife
Check your ignition. An ignition problem will often mimic a fuel problem.
fordwife is offline   Reply With Quote
Old 06-14-2021, 09:08 AM   #4
jayvee34
jayvee34's Avatar
Had that to happen a couple of times with my 47 Ford coupe. While driving around 40 to
45 MPH I would down shift to 2nd gear and hold the 40 to 45 MPH steady for about a
block and then shift to high gear. It would smooth out. what was happening was the car
was loading up and fouling out the plugs. Check your plugs.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 06-15-2021, 05:29 AM   #5
flatmotor40
I've had problems before with moisture in the cap but it would completely die and had to change cap.Thought about some water in gas but it seems to run and I have to really get the rpm up and it goes up and down till it smooths out.Surges while I run it high rpm.Thanks
