08-01-2021, 09:35 PM | #621 |
Re: photo1-1-window
40 v8 |
08-02-2021, 09:51 AM | #622 |
Re: photo1-1-window
Raised Deck |
08-02-2021, 12:24 PM | #623 |
Re: photo1-1-window
REAR BACKING PLATES
LATE STYLE '42-'48 .. Last edited by V8COOPMAN; 08-02-2021 at 12:52 PM. |
08-02-2021, 01:13 PM | #624 |
Re: photo1-1-window
Spindle |
08-02-2021, 01:51 PM | #625 |
Re: photo1-1-window
1941 STEERING-Running Differences __________________________________________________ ________ LATE '41 .. |
08-02-2021, 04:02 PM | #626 |
Re: photo1-1-window
Lawson .....Not unlike "51-Merc..." here, I've GOT to make a comment or two. Highest on the list, and once again for you......POSTING PICTURES HERE AIN'T HARD!! Myself, as well as MANY others, have been posting photos here for years, and it is no harder to post a picture than it is to suck a sip of beer. Ya know, a few years back, a bunch of folks asked Ryan to change the format over on the H.A.M.B. And yeah, it's a little easier to post pics over there now, but SOOO much more changed with the new format, and it affected ME so negatively that I haven't been back since.........but that's MY particular problem! I pray that Ryan leaves this alone here...........IT'S WONDERFUL as-is! You should note that "tubman" is one of our more-knowledgeable and most-generous members with sharing his wisdom. He is also quite active with sharing pictures here for others. This morning, it was OBVIOUS that he only had ONE small question about a rare, technical issue.....NOT his inability to post pictures on the FordBarn. If there is one thing that I have learned about successfully fitting-in to this type of community, it is that whenever a subject comes up regarding something that I know little or nothing about, I usually just keep my mouth shut. Like "51-Merc...." alluded to, there's a lot to be said about "difficult for you, easy for me". You were an attorney probably for eons. I personally cannot imagine sitting through 'law school', much less REMEMBERING most of what you learned toward that profession. Funny thing is that YOU (on SEVERAL occasions) have had to ask someone here to explain how to RE-SET your 'signature' line, not to mention how many times you have repeatedly asked how to empty your PM box......two procedures that couldn't possibly be any easier. I'm not knocking you for it.....just trying to point-out that some things come easily for folks, while others just have a hard time catching-on to the simplest of procedures. So with that, I am going to politely and sincerely beg you to quit suggesting that The Boss change this place up. DD |
08-03-2021, 10:22 AM | #627 |
Re: photo1-1-window
VIDEO "EARLY FORD PARTS STORE - San Dimas https://www.youtube.com/watch?v=icTK5IJY7KE - Phone Orders - Call (909) 305-1955 - Email - [email protected] . |
08-05-2021, 03:33 AM | #628 |
Re: photo1-1-window
Mods to FRENCH Block & Pan Vent Use PRE-'49 Flywheel w/4" Crank! |
08-05-2021, 06:15 PM | #629 |
Re: photo1-1-window
WATER Pump Bolt
08-06-2021, 02:41 AM | #630 |
Re: photo1-1-window
ENLARG & POST Pictures Narrative
____________________________ https://www.fordbarn.com/forum/priva...m&pmid=1473964 . |
08-11-2021, 07:43 PM | #631 |
Re: photo1-1-window
1935 & 1936 Spindle COMPARISON. 1935 on LEFT! 1935 1936 . Last edited by V8COOPMAN; 08-11-2021 at 07:58 PM. |
08-12-2021, 12:13 AM | #632 |
Re: photo1-1-window
1935/1936 Spindle Comparison |
08-13-2021, 10:11 AM | #633 |
Re: photo1-1-window
Merc Riser Mount |
08-13-2021, 05:59 PM | #634 |
Re: photo1-1-window
39 standard wiring
08-17-2021, 10:14 AM | #635 |
Re: photo1-1-window
Tank Pods
08-19-2021, 11:29 AM | #636 |
Re: photo1-1-window
EARLY '40 Perch Bolts WITH Sway Bar __________________________________________________ ____ '40 Perch Bolts - NO Sway Bar __________________________________________________ ____ LATER '40 Perch Bolts WITH LATE Sway Bar __________________________________________________ ____ EARLY '40 Sway Bar __________________________________________________ ____ LATE, Improved '40 Sway Bar . |
08-19-2021, 12:18 PM | #637 |
Re: photo1-1-window
08-22-2021, 06:58 PM | #638 |
Re: photo1-1-window
40 Clutch Release
08-25-2021, 10:38 AM | #639 |
Re: photo1-1-window
JIM'S 4-Speed
08-26-2021, 11:58 AM | #640 |
Re: photo1-1-window
Natural Rodent Control |
