Old 11-24-2020, 02:59 PM   #1
Pandersen33
Pandersen33's Avatar
Default Intake gasket failure
Ive noticed now on 2 seperate engines that im having an issue of the outside of the heat riser holes tearing away from the intake gasket. Is this a common issue or should I be looking for a cause? Both planes are square and intakes were true. I used white grease all over the gasket. Im sure this could also be a reason i was having such an issue tuning the carbs if air can get into the intake from there?
Pandersen33 is offline   Reply With Quote
Old 11-24-2020, 04:17 PM   #2
flatjack9
flatjack9's Avatar
Default Re: Intake gasket failure
Never ran in to this problem. I would say it is rare.
Old 11-24-2020, 05:56 PM   #3
cadillac512
cadillac512's Avatar
My recent 255 Merc build did the same. Intake gasket was from a "Best Gasket" full set and was a two layer paper construction. It tore at the holes you refer to and also separated and migrated inward at the rear,causing an oil leak there.
I fixed the problem by using a gasket like Mike Driskill at 3rd gen (35fordtn) sells...it has a metal center sandwiched in it and is far better construction. I highly recommend it.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 11-24-2020, 06:30 PM   #4
russcc
That's great info, thank you for posting.
