Old 08-02-2021, 10:32 AM   #1
OL JENNY
OL JENNY's Avatar
Default Top Dressing for Original Top
I have a good friend who is wondering what would be a good top dressing for an original top. This car has been in his family since it was new, and he wants to keep it original and not install a new vinyl top. His top shows evidence of tiny cracks and does leak in rain. Since he is not yet a member of the Barn I said I would reach out on his behalf.
Thanks,
OL JENNY
OL JENNY is offline   Reply With Quote
Old 08-02-2021, 10:41 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Top Dressing for Original Top
I use Rubber/vinyl from Griots Garage great for all tires etc armor all not good
www.whidbeymodelaclub.com
Old 08-02-2021, 12:37 PM   #3
duke36
If cracking, may want to check SEMproducts for a flexible coating/vinyl renewer. A reminder that the original tops were most often a lacquer coated fabric.
duke36 is offline   Reply With Quote
Old 08-03-2021, 10:44 AM   #4
160B
160B's Avatar
I acquired a 1931 160B 20 plus years ago with an original top. When I acquired the vehicle the top had some cracks and leaks. I have used Dupont Thickote top dressing and sealed the top and have no leaks. This is a product from the 40's and 50's and can be found at swap meets and on e-bay. See the below photos.
I also have used a product called big stretch, a water based caulk. I use it first to caulk up any wide gaps and when it dries I use the top dressing. Big stretch is very effective to seal any leak. It is water based so you can calk a leak, ie around a front window, use a wet sponge to wipe away any caulk and it seals without any visible presence that you caulked around a window.
https://www.sashco.com/products/big-stretch/
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
