Old 07-26-2021, 05:20 PM   #1
motordr
Default Magneto Condenser
I have been using the magneto condensers on both 12 volt negative ground distributor circuits and 6 volt positive ground circuits without a single failure in close to ten years.
Recently someone local had what sounds like a condenser failure or destruction on a 6 volt positive ground system, ‘41 Ford with a Dennis Carpenter coil. Is it possible that some of the newer magneto condensers are polarity sensitive?
My condensers do not indicate a + or - on them.
Has anyone run into this type of failure or know what might cause it? Thanks.
motordr is offline   Reply With Quote
Old 07-26-2021, 08:44 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Magneto Condenser
condensors dont care about the polarity , works either way ..I stock the Vertex units at $32 each ......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-27-2021, 04:22 AM   #3
mike42
mike42's Avatar
I’ve got a standard ‘40 V8. Does this just replace the current one I have which is the NAPA 200.
Thx
mike42 is offline   Reply With Quote
Old 07-27-2021, 10:02 AM   #4
motordr
Thank you Bubba, it’s good to get that confirmed. Ted
Old 07-27-2021, 05:17 PM   #5
35fordtn
35fordtn's Avatar
Carpenter is a great company and we are a dealer for them and refuse to stock their coils. But... their 37-41, and 42-48 for that matter coils will fail.. It's not a matter of if, but rather when...
Old 07-27-2021, 05:47 PM   #6
G.M.
Thx
Stick with the IH-200 from NAPA G.M.
www.fordcollector.com
