05-28-2016, 02:58 AM | #1 |
cam shaft centre line
Any one know the centre distance between the camshaft and the crankshaft centres.
also the bore diameter of the block were the valve guides fit. Thanks Lawrie |
05-28-2016, 03:31 AM | #2 |
Re: cam shaft centre line
Lawrie Have a look on Vince Falters site , ford garage.com. I know he has the center line measurements you need . Good luck
05-28-2016, 05:02 AM | #3 |
Lawrie I set up for 4.155"
05-28-2016, 05:29 AM | #4 |
Thanks Guys that is exactly what I needed.
Lawrie |
05-28-2016, 07:02 PM | #5 |
Thanks ,Measured the centres this morning,.008 under,
Lawrie |
05-29-2016, 11:58 AM | #6 |
05-29-2016, 03:01 PM | #7 |
Dan did the same for me they mesh perfectly. Thanks Dan...
05-30-2016, 10:19 AM | #8 |
Four and a half years after this thread, I had to call on Dan to provide me with a -.005" timing gear to salvage a "fresh" short block that has been haunting me for decades after a run-in with America's Sweetheart antique engine family. The mains had been line bored just a little off. Hoping that it's not your problem just keep the Dan option in mind if it continues to destroy timing gears. Good Luck: Fred A
05-30-2016, 03:50 PM | #9 |
Sure will, I have just yesterday fixed the main bolts looseness up,and will then look at the fix for the cam.
Lawrie |
05-30-2016, 04:36 PM | #10 |
Lawrie I am sure you know but check center line front and back
05-30-2016, 04:41 PM | #11 |
Sure will
Lawrie |
06-11-2016, 12:58 AM | #12 |
Would any one have an e/mail for Dan Mc eachern.
to save me ringing at an ungodly hour for me. Thanks Lawrie |
06-11-2016, 03:47 AM | #13 |
Lawrie try
[email protected] |
06-11-2016, 04:53 PM | #14 |
Thanks Colin,
I,m onto it. Lawrie |
