Old 06-27-2022, 07:55 PM   #1
Robbie Horn
Robbie Horn's Avatar
Default Cracked Model A Block
Has anyone repaired one this bad? It’s cracked down 2 cylinders & all the way down the center head stud boss. I’m in Axtell Texas if anyone close has one to sell.
File Type: jpg 713FF47F-8BA7-4AB9-8B35-C8804025E353.jpg (58.7 KB, 264 views)
Robbie Horn is offline   Reply With Quote
Old 06-27-2022, 08:59 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Cracked Model A Block
With that crack extending down the cylinders, I don't think stitching is an option. I'm afraid you should be looking for a new block to rebuild.
I don't know how high your pennies are stacked but I think a very viable option would be one of the new Burtz blocks. They cost about the same as reboring an old one and doing the Babbit bearings and you will have an all new and far superior engine. You can use all of the attachments from your current engine like head, cam shaft, distributor, water pump etc - The lot.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 06-27-2022, 09:11 PM   #3
old ugly
old ugly's Avatar
my opinion. try to find another block rather than attempt to repair.
you would probably have to stich it then sleeve it, you may as well start with a better block that is within rebuild specs.
or a new block.
the problem with a "good runner". the seller says its a "good runner" or "all gone through" or "ran good when parked" and you end up doing a complete rebuild anyway. buyer beware.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 06-27-2022, 11:23 PM   #4
CWPASADENA
CWPASADENA's Avatar
I agree, time for a "new" block.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 06-28-2022, 06:04 AM   #5
ronn
go to local CL
many good complete motors for around 250.
Old 06-28-2022, 10:27 AM   #6
rotorwrench
rotorwrench's Avatar
I can't tell for sure but is looks like the two cylinders already have sleeves.
Old 06-28-2022, 05:02 PM   #7
AL in NY
AL in NY's Avatar
I believe that is the problem Terry Burtz has mentioned which is caused by torquing the #1 head nut at too high a starting torque when torquing the head. Terry suggests using a starting around 10 or 15 lbs and not torquing the head in a circular pattern but start torquing at the rear of the head and work your way forward, increasing torque by 10 or 15 lbs each pass.
AL in NY
AL in NY is offline   Reply With Quote
Old 06-28-2022, 06:22 PM   #8
Synchro909
Synchro909's Avatar
Probably so but it is all too late for that block. Something for the owner to remember when he assembles a new engine.
Old 06-28-2022, 06:54 PM   #9
nkaminar
nkaminar's Avatar
Pete Aardema and Kevin Braun who built the world's fastest Model A engine put a clamp around the top of the engine to keep it together and prevent this kind of crack. They say the Model A engine is weak in this respect. See https://www.youtube.com/watch?v=T29HFhrbT_s
Where he talks about the block clamp is at 7:50 in the video.
Old 06-29-2022, 12:30 AM   #10
Phil Brown
Phil Brown's Avatar
The way that clamp tightens is a brilliant way of doing it, using right-hand threads in both sides but different thread pitches
Phil Brown is offline   Reply With Quote
Old 06-29-2022, 06:27 PM   #11
Synchro909
Synchro909's Avatar
Back in the 1970s, I rode an Austrian made motor scooter. A poor student then, I couldn't afford anything recent - mine was from the late 1950s - early 60s. The flywheel was removed with a special puller that used threads of different pitches that we knew as a differential pitch puller.
The principle is not new.
Old 06-30-2022, 10:59 AM   #12
katy
katy's Avatar
Sounds like an interesting type of tool, can you provide some more information on it?
Tnx, Ken
Old 06-30-2022, 11:13 AM   #13
WHN
Guy’s, these engines have lasted almost 100 years. They deserve a rest.
Try comparing the Model A and it’s engine to any low cost mass produced car today.
What will people be saying about them in 100 years?
Model A’s and Model T’s, great cars.
Enjoy.
WHN is offline   Reply With Quote
Old 06-30-2022, 11:23 AM   #14
jack backer
Use a timesert in the center head stud bore, don’t worry about the rest, cracks connecting the water jacket are harmless.
jack backer is offline   Reply With Quote
Old 06-30-2022, 03:47 PM   #15
Synchro909
Synchro909's Avatar
Tnx, Ken
As I remember it (my memory is being tested), the flywheel was pulled by screwing in a "bolt" that went into the end of the crankshaft a few turns. There was a hollow bolt that went over the first one. It screwed into the flywheel, then the two were locked together. The bolt into the flywheel was a coarser thread than the one in the crank. By turning them together, the flywheel was forced away from the and of the crankshaft till it snapped free. Easy and no damage, just like when you have the right tool for any job. The mechanical advantage this gave was dependant on how close the two thread pitches were. The closer, the greater the "pull".
The scooter was a "PUCH" brand. I doubt you guys had them. They had a 2 stroke engine of 150 cc with oil mixed in the fuel as you filled. I could get a reliable 100 miles per imperial gallon. Top speed was about 60 mph and it took me everywhere. Those were the days!
Old 06-30-2022, 04:18 PM   #16
john in illinois
john in illinois's Avatar
Those were the days. Had a 125cc BSA bantam. Tank cap measured oil to mix.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 06-30-2022, 04:24 PM   #17
Synchro909
Synchro909's Avatar
John
My wife had one of those though her sister rode it more. They were a more conventional motor cycle but they were not for me.
Old 07-01-2022, 07:05 PM   #18
Chris Haynes
Chris Haynes's Avatar
https://www.brattons.com/BURTZ-BLOCK...ductinfo/7095/
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 07-01-2022, 07:15 PM   #19
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Are the sleeves cracked too? If not,you could verify oil water contamination with a block pressurizing test.
Old 07-02-2022, 10:16 PM   #20
Robbie Horn
I'm going to fix it. Just wanted to see if anyone on here has repaired one like this. Also was hoping someone in my area might have a engine for sale. These blocks are made out of some good stuff not like all this new Chinese metal with all the impurities. Only the good welders on here will know what I'm talking about. I'll post pics when I do it. Right now I'm working on my chassis to get the body on it.
