06-25-2022, 08:33 AM | #1 |
Synchro kit?
Does anyone make a synchro kit for stock 31 transmission? I’m rebuilding a spare transmission and would to add synchros if possible.
06-25-2022, 09:24 AM | #2 |
Re: Synchro kit?
06-25-2022, 09:56 AM | #3 |
Re: Synchro kit?
06-25-2022, 12:52 PM | #4 |
Re: Synchro kit?
Or, install a later model transmitter such a '38 or '39.
06-25-2022, 09:29 PM | #5 |
Re: Synchro kit?
I've got to ask Patrick L - Why do you use the term transmitter instead of transmission in various posts on this forum. I thought it might be a term used in other countries, but notice you are in the good 'ole USA. I'm just an inquiring mind trying to learn something new.... : )
Craig |
06-25-2022, 09:53 PM | #6 |
Re: Synchro kit?
06-26-2022, 01:25 AM | #7 |
Re: Synchro kit?
I don't understand the need for syncros. It doesn't take a rocket scientist to learn the timing to shift without grinding gears. I only use the clutch for starting and stopping. All shifting is done without using the clutch. But then I am 77 years old and have been driving stick shifts all my driving life.
I am putting a '39 trans in my A. Not for syncro shifting but to hold up under the 85 HP my engine is putting out. I didn't want to subject that little A gear box to more than double the HP it was designed to take.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
06-26-2022, 03:45 AM | #8 | |
Re: Synchro kit?
While your first sentence is right, please don't encourage others to shift without using the clutch. Every time I read about this practice (no matter if it's a bike or a car) I cringe. But I guess only God knows why some people feel the need to shift without using the clutch... |
06-26-2022, 05:54 AM | #9 | |
Re: Synchro kit?
No special reason, just to be different I guess. It transmits power. When the hood is open [on a normal vehicle] I usually call it the mouth. |
06-26-2022, 08:33 AM | #10 |
Re: Synchro kit?
The model A transmission with it's straight cut gears and lack of synchonisers isn't much weaker that the model B transmission. It's just more of a challenge to shift. Learning to throttle up and match rpms for a downshift to 2nd takes experimentation to get done with minimal gear grinding. It works the same way with upshifting but it can be more difficult to slow the transmission gears down for upshifting unless a person double clutches. When upshifting there is no way to know by ear how fast the 2nd gear is turning when shifting from 1st to second. 2nd to high is a bit more predictable since the 2nd gear is dogging onto the input shaft and a person can hear how fast the engine is turning that shaft.
06-26-2022, 10:10 AM | #11 |
Re: Synchro kit?
Do people experience grinding when going from 1st to 2nd? That’s never happened to me and I’m terrible at shifting.
06-26-2022, 10:27 AM | #12 |
Re: Synchro kit?
I agree with y'alls, no need for synchros. The only reason I would concider a Mitchell or othe transmission is the change the gear ratios, especially between second and third. Big reason I installed a Mitchell O/D, so I could split gears.
06-26-2022, 10:43 AM | #13 | |
Re: Synchro kit?
Ruth "Sometimes you really DO need to read the whole thread" |
06-26-2022, 12:00 PM | #14 |
Re: Synchro kit?
I thought maybe a spell check thing , sometimes automotive terms are “corrected” by spellcheck.
06-26-2022, 12:02 PM | #15 |
Re: Synchro kit?
Thanks. That's why I asked politely....didn't want to insult you in case it wasn't 'in jest' or just to be 'different'.
06-26-2022, 12:11 PM | #16 |
Re: Synchro kit?
I learned to drive on a Model A so using the non synchro transmission is second nature to me. The only trouble you can get into is if you miss a down shift when you really need it like going down a steep grade. Then it is really nice to have the synchro transmission, or three feet.
06-27-2022, 05:26 AM | #17 | |
Re: Synchro kit?
Depends on how you change gears. If you change slow enough it won't grind. If you want / need to change the gears fast, it will most likely grind. I've come to use specific points for up- and downshifting that work best for my car, for example ~ 18 to 20 mph from 3rd to 2nd. 9 out of 10 times the gearchange is completely silent at this speed. It's just that I match the engine speed best around that speed. |
06-27-2022, 10:03 AM | #18 | |
Re: Synchro kit?
06-27-2022, 12:08 PM | #19 |
Re: Synchro kit?
Guess I am...with a college degree and 28 years as a public school technology teacher, probably need more 'edyoukatin' from Whatsumater U.
Craig |
06-28-2022, 01:01 PM | #20 | |
Re: Synchro kit?
You either have the talent and coordination to do it or you don't.
