Old 07-18-2020, 06:30 PM   #1
av8coupe
Default Temperature sender
I am about to install a temperature sender in an aluminum head. The instructions say not to use Teflon tape because it could affect accuracy. Would anti-seize be OK? I’m concerned about the threads on removal if needed. Thanks, Dave
av8coupe is offline   Reply With Quote
Old 07-18-2020, 07:44 PM   #2
JSeery
JSeery's Avatar
Default Re: Temperature sender
The issue is the sender is a ground path for the gauge. The unit must have a good ground to the head to function, so any sealant much be conductive.
Old 07-29-2020, 11:29 AM   #3
av8coupe
Ok thanks
Old 07-29-2020, 11:52 AM   #4
19Fordy
19Fordy's Avatar
I use just a tiny dab of anti seize. I had to make an adapter because the length of the sender bottomed out in the alum head. You probably won't have this problem.
