Old 04-26-2015, 09:12 PM   #1
Itchy-Pit
Itchy-Pit's Avatar
Default 1933 Radiators Car vs Pickup
What are the differences in the two please? I have collected a variety but now I need one for the Roadster. Thanks in advance! Dennis
Itchy-Pit is offline   Reply With Quote
Old 04-26-2015, 09:32 PM   #2
Krylon32
Default Re: 1933 Radiators Car vs Pickup
I always thought they were the same with different brackets for mounting the shell?
Krylon32 is offline   Reply With Quote
Old 04-26-2015, 10:12 PM   #3
PhoenixFear
Brass works seems to have a good bit of information on this.
Car:
http://www.thebrassworks.net/shop/Re...cf4a157d6955a0
Truck:
Hope this helps, they list this as a truck radiator though. I'm not sure if they are referring to a bigger truck or a pickup. I don't know if or what the differences might be between truck and pickup.
PhoenixFear is offline   Reply With Quote
Old 04-26-2015, 10:15 PM   #4
34pickup
34pickup's Avatar
Krylon32 is correct. I used a car radiator in my truck. All I had to change is the brackets bolted to the side of the radiator.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 04-27-2015, 12:06 AM   #5
Flowmeister
Flowmeister's Avatar
I posted this question some time ago on the HAMB, all the replies
back were that they are the same.
Flowmeister is offline   Reply With Quote
Old 04-27-2015, 07:10 PM   #6
Itchy-Pit
Itchy-Pit's Avatar
Thank you all that have replied. Much appreciated!!!
Old 04-27-2015, 08:36 PM   #7
epw1949
The V/8 Radiators are the same,but the sides are not,so in order to use a car radiator in a pickup you would have change the radiator sides so the grille mounting brackets can be attached to mount the pickup grille,and vise-a-versa when using a pickup radiator for a car,so the car grille can be attached.I hope this helps.E.P.Williams
epw1949 is offline   Reply With Quote
