Old 02-04-2015, 02:11 PM   #1
Ford_Freddie
Default How to remove grease in the steering box?
I bought my Model A a few month ago. Today I wanted to check the oil level of the steering box - but there was no oil. Someone put grease in it. How can I remove the grease? Is it possible to solve it with kerosene? I hope I don't have to remove the steering box. Thank you in advance.
Ford_Freddie is offline   Reply With Quote
Old 02-04-2015, 02:33 PM   #2
J Franklin
J Franklin's Avatar
Default Re: How to remove grease in the steering box?
You might be better off just adding some light oil and it will help liquify the grease.
Old 02-04-2015, 02:45 PM   #3
Patrick L.
Patrick L.'s Avatar
Yep, I agree. Just dig out what you can and then add the oil, heavy oil.
Old 02-04-2015, 02:54 PM   #4
Ford_Freddie
Thank you very much. I will try it with 600W oil.
Old 02-04-2015, 02:55 PM   #5
Dollar Bill
Dollar Bill's Avatar
If it's filled with grease, there's a good probability the seals are shot and even 90 weight will run right out - At least that's what mine did.
I'm waiting for it to stop leaking and add 600W which is not supposed to leak out.
The only way that I know to get all of the grease out is to R&R the sector.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 02-04-2015, 03:02 PM   #6
billwill
re fill with STPBest for stering box Good luck
billwill is offline   Reply With Quote
Old 02-04-2015, 03:04 PM   #7
C26Pinelake
My neighbor built a gun looking adapter that fits on the end of his shop vacuum hose. It is amazing the amount of suction created when you go from a 4 inch opening and reduce if to a half inch orifice.
Wayne
C26Pinelake is offline   Reply With Quote
Old 02-04-2015, 03:06 PM   #8
Ford_Freddie
STP? Could you please tell me what it is? Here in Germany we don't know it.
Old 02-04-2015, 03:06 PM   #9
Fred K-OR
Fred K-OR's Avatar
The guys above know what to do, should like a good plan.
Is it a 2 tooth or a 7 tooth box? Either one, you may want to check on occasion to see if the oil you put in might get into the light switch down at the bottom of the column. If this happens, this may be the reason why they used grease.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 02-04-2015, 03:08 PM   #10
Ford_Freddie
It is a 2 tooth box.
Old 02-04-2015, 03:24 PM   #11
Brentwood Bob
before you put in the oil why not replace the end plate with either:
brattons' housing end plate #a3568-T and a new gasket.
or: Snyders" a3568-t, and buy the steering housing gasket set #a3581-bs.
or at least loosen the harness and see if the end plate has been retrofitted with the above parts.
Or I guess you could add the oil and see what happens next.
Bob
Brentwood Bob is offline   Reply With Quote
Old 02-05-2015, 04:59 AM   #12
Bruce of MN
Bruce of MN's Avatar
This is STP:
http://www.amazon.com/STP-Oil-Treatm...ywords=stp+oil
Old 02-05-2015, 05:16 AM   #13
Dollar Bill
If you decide to use STP, it has the consistency of honey and may pose a problem trying to pour it through the 3/4" fill port in your gear box. It will thin out if you heat it up.
Old 02-05-2015, 06:05 AM   #14
Charlville
Charlville's Avatar
Hi Ford Freddie
You can get STP products on Amazon UK which should save on shipping v the USA
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 02-05-2015, 08:56 AM   #15
Ford_Freddie
Thank you all for your help. It's a great forum.
Old 02-05-2015, 09:31 AM   #16
John Duden
John Duden's Avatar
Run hydraulic oil for awhile. That will soften and dissolve the grease
John Duden is offline   Reply With Quote
