06-02-2021, 01:07 PM | #1 |
Replacement mounting/firewall nut for cast iron sediment bulb
Took my cast sediment bulb off to clean and paint and lost the mounting nut and washer. Bought one from Brattons but they called and said they’re out. No one else seems to have one. Anyone have any advise on sizing or source so I can get it back in the car for now?
Sent from my iPhone using Tapatalk |
06-02-2021, 02:53 PM | #2 |
Re: Replacement mounting/firewall nut for cast iron sediment bulb
I would try a hardware store or industrial supply. You are looking for
a 3/4-16 hex jam nut. |
06-02-2021, 03:44 PM | #3 |
the thread on this nut was 3/4-16, but it was also very wide and thick. Bratton's had to have a machine shop make them special for them. But as with a lot of things that shop closed, and the quotes from new shops that we are receiving right now on part prices or quantities are not pretty.
06-02-2021, 03:50 PM | #4 | |
06-02-2021, 04:28 PM | #5 |
McMaster-Carr has 3/4-16 hex nuts by 1" thick with 1-1/8" wrench flats for $10.35 for 10 pieces.
06-02-2021, 04:35 PM | #6 |
06-02-2021, 05:11 PM | #7 |
I have one I will give you if you PM me your address.
06-02-2021, 08:34 PM | #8 |
06-02-2021, 08:57 PM | #9 |
We have them at Berts
06-02-2021, 08:59 PM | #10 |
been a few years sinsce I saw either one, but pretty certain the sediment bowl nut is bigger....
our next Model A is out there in the unknown...... |
06-02-2021, 09:14 PM | #11 |
Well it was bugging me that I couldn’t find it as I remember taking it off and it could only be in a couple of places. So I once again pulled everything apart. To no avail.
Then I thought, “I didn’t throw them in the rust remover solution and leave them in there did I?” Bingo So thank you everyone and for future reference for anyone looking for one... Indeed it’s 1-1/8 across the flats. 3/4 coarse pitch (16?) thread. One side flat and one chamfered. Thickness is 0.317 on mine. Lock washer is a simple split lock washer. 3/4 ID, 1-1/8” OD and 1/16” thick. |
06-02-2021, 09:16 PM | #12 |
Separate post as tapatalk won’t let me upload more than one photo at a time ...
06-02-2021, 09:18 PM | #13 |
