05-22-2021, 11:05 AM | #1 |
Panel Delivery Rear door handle help needed
A friend of mine is in need of help. He has a Panel Delivery truck and is ready to install the rear door handle but has problems connecting the inside door locking system. What is he missing. Pictures show what he has. All help appreciated Joop .. Last edited by Joop; 05-22-2021 at 01:55 PM. |
05-22-2021, 02:27 PM | #2 |
Re: Panel Delivery Rear door handle help needed
Looks like the handle shaft is a little short, can't get the locking C-clip on.
Should that inside plate be recessed into the door? I don't know Is there a piece missing? I don't know All I do know is that what is shown looks pretty good, how about a pic of the rest of the car?
05-22-2021, 05:39 PM | #3 |
These are photos of the handle assembly on my 1931 Panel. A bit different.
Hope they help
Bob from Northport Northport, Michigan Last edited by Bob from Northport; 01-24-2022 at 09:39 PM. |
05-22-2021, 06:48 PM | #4 |
THanks Bob
05-23-2021, 07:59 AM | #5 |
Anymore help out there.
05-23-2021, 08:25 AM | #6 |
You might forward question & photos to Jim Dix, who restored a '29 Panel. (607)562-3711 [email protected] jb |
05-23-2021, 10:36 AM | #7 |
Rubber pad under escutcheon too thick? There were no phillips head screws used originally so perhaps back plate isn't set correctly or could be recessed as suggested ? Also, those handles are not available so don't change the shaft length, etc. The Nov 2015 issue of the Restorer Mag. has an article about the '31 Panel and shows a different inside latch assembly with an outside T locking handle that may be shorter shaft length.
