02-10-2021, 10:16 PM | #1 |
penrite lube
does anyone in the US sell Penrite steering box lube?
02-10-2021, 10:52 PM | #2 |
Re: penrite lube
02-11-2021, 10:01 AM | #3 |
Re: penrite lube
thank you CW
John |
02-11-2021, 02:01 PM | #4 |
Re: penrite lube
It is mentioned in these two threads that the Penrite is 00 grease. I picked up some 00 grease at Tractor Supply for $5 and am pleased so far. This could be a cheaper alternative to the Penrite.
https://www.fordbarn.com/forum/showt...hlight=Penrite https://www.fordbarn.com/forum/showt...=278772&page=3 Last edited by 7_Zero; 02-11-2021 at 02:07 PM. |
02-11-2021, 06:09 PM | #5 |
Re: penrite lube
I use John Deere corn head grease. About $4.50 a tube where I live in Illinois.
Works great. |
02-11-2021, 06:54 PM | #6 |
Re: penrite lube
02-11-2021, 07:16 PM | #7 |
Re: penrite lube
02-11-2021, 08:05 PM | #8 |
Re: penrite lube
Lube from tractor supply is exact same stuff as Pennritw at 1/4 the price.
I dig coal, which provides motivation for EVs. |
02-11-2021, 11:25 PM | #9 |
Re: penrite lube
Which tractor lube?
02-12-2021, 09:09 AM | #10 |
Re: penrite lube
This tractor lube at Tractor Supply
Bob from Northport Northport, Michigan Last edited by Bob from Northport; 01-24-2022 at 09:39 PM. |
02-12-2021, 05:11 PM | #11 |
Re: penrite lube
It can't be very thick if it comes in a bottle with a neck like that. I'm sure the Penrite steering box lube I use is thicker than that would be.
02-12-2021, 10:35 AM | #12 |
Re: penrite lube
John, not to hi-jack your thread however just to keep muddy waters stirred up a bit, HERE is some of my thoughts on the subject of grease in a steering gearbox. Maybe y'all will agree or disagree??
02-12-2021, 11:01 AM | #13 |
Re: penrite lube
Is it just terminology?
I think of "lube" like 600w oil and "grease" like I use in a grease gun. Does Penrite make both? |
02-12-2021, 11:32 AM | #14 |
Re: penrite lube
Penrite makes numerous products. Penrite Steering Box Lube is 1200w.
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 02-12-2021 at 11:42 AM. |
02-12-2021, 05:34 PM | #15 |
Re: penrite lube
It is NOT. It is the same because I have both in the shop
Bob from Northport Northport, Michigan |
02-12-2021, 07:15 PM | #16 |
Re: penrite lube
Must take a long time to get it out of the bottle, especially in cold weather.
02-12-2021, 07:41 PM | #17 |
Re: penrite lube
I think many folks do like I do and heat it up via a pot of hot water before filling.
02-13-2021, 09:36 PM | #18 |
Re: penrite lube
May I ask, why do we even think we need to change the lube from the 600W to begin with?
02-13-2021, 10:29 PM | #19 |
Re: penrite lube
02-14-2021, 12:18 PM | #20 |
Re: penrite lube
