Old 04-11-2017, 07:59 PM   #1
OLDTINDEALER
Default Couple model A parts ID help please
Found tucked away in shed during spring cleaning.
First, is this hinge/cowl section from a pick up?
Second Cross braces are both marked lower, but lower what?? I forgot.
Third Top piece is a what? Can't seem to place it.
OLDTINDEALER is offline   Reply With Quote
Old 04-11-2017, 09:03 PM   #2
vern hodgson
Default Re: Couple model A parts ID help please
Upper right I believe is a door post from a 29 roadster??? The lower parts appear to be side pieces for a radiator, and if you want to part with them, the radiator parts I could certainly use them.
vern hodgson is offline   Reply With Quote
Old 04-11-2017, 09:13 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Good call on the radiator pieces, but I don't recognize the oval pattern and the bracket on one end.
Old 04-11-2017, 09:39 PM   #4
vern hodgson
That's getting into more detail than I know about. And I meant the upper left photo.
