Old 01-12-2021, 04:03 PM   #1
RB_Nielsen
RB_Nielsen's Avatar
Arrow Fog Light Switch Help
Looking for a schematic/info showing how to connect this old fog light switch that has 3 electrical posts and a fuse
RB_Nielsen is offline   Reply With Quote
Old 01-12-2021, 05:29 PM   #2
5851a
Default Re: Fog Light Switch Help
Is it a 3 position switch, like off one and 2. Just as a guess I would say power goes in on the terminal with the fuse and out on the other 2. Maybe a combination of fog on one position and backups on other. Should be easy to test with meter or test lamp bulb.
5851a is offline   Reply With Quote
Old 01-12-2021, 05:36 PM   #3
CarlG
CarlG's Avatar
Here's a copy of the instruction sheet from Unity:
When wired up like the instructions show, the tail lights will come on anytime you have the fog lights turned on.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-12-2021, 11:49 PM   #4
GRutter
GRutter's Avatar
I believe the switch itself was illuminated.
Hooked up to the tail-lights so that anytime the lights were on, the switch would illuminate. Might want to check to see if it has a bulb in it, and if it is 6 or 12v.
GRutter is offline   Reply With Quote
Old 01-13-2021, 12:40 PM   #5
RB_Nielsen
RB_Nielsen's Avatar
Thank you all for your help, and thanks especially CarlG for the set of instructions that were exactly what I needed - perfect!
Old 01-13-2021, 02:52 PM   #6
JohnB15632
JohnB15632's Avatar
May I ask, what is the purpose of the fog lights? Is this an accessory, or did Ford install them originally?
Thanks,
JohnB15632 is offline   Reply With Quote
Old 01-13-2021, 05:25 PM   #7
RB_Nielsen
RB_Nielsen's Avatar
Thanks,
You've ask a good question. I use a pair of 5" accessory fog lights mounted on the front bumper as both daylight driving lights AND for turn signal lights. I suspect they are not considered officially sanctioned in terms of judging but my rationale is they provide unmistakable notice to oncoming traffic of my Model A being in traffic and when necessary signal my intention of making a turn
Old 01-13-2021, 06:16 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Not to mention they look Bitchin'.
RB, never thought of using them for driving lights. With 30w bulbs X 2 they really pull the amps. I will try that out next time I'm out.
Old 01-14-2021, 02:19 PM   #9
CarlG
CarlG's Avatar
Check out my pictures in post #3. I converted the Unity Fog Lights from Sealed Beam to LED, thus eliminating the huge current draw. I also intend on using them for driving lights. My turn signals are in the cowl lights (also LED).
Alaskan A's
Old 01-14-2021, 06:34 PM   #10
Y-Blockhead
Nice!! I will have to look into that. What did you use for lenses?
Old 01-14-2021, 10:34 PM   #11
CarlG
CarlG's Avatar
I bought these on Amazon:
https://www.amazon.com/GS-Powers-Chr...s%2C257&sr=8-4
Alaskan A's
Old 01-25-2021, 02:52 AM   #12
RB_Nielsen
RB_Nielsen's Avatar
CarlG - Great Amazon idea/find I'm definitely going to check them out. I've had to replace one fog light bulb already, and talk about needing to delve into off-brand/screwy misbegotten hardware. Going to LED will be a godsend
Old 01-26-2021, 12:56 AM   #13
Y-Blockhead
I will check those out. I prefer the look of the amber lenses tho when the lights are off instead of the clear lense.
Old 01-26-2021, 01:25 PM   #14
CarlG
CarlG's Avatar
I had a couple of thoughts there: 1) I wanted to approximate the same look as the headlights and cowl lights, hence the clear lenses. By using amber LEDs they turn color when on, as do the turn signals in the cowl lights. 2) to further the same look as the stock headlights & cowl lights, these have a flat front rather than the round look of the original sealed beam.
Each to his own!
Alaskan A's
Old 01-26-2021, 02:47 PM   #15
Y-Blockhead
Each to his own!
Carl, Yes, it's all good. Looking at Amazon, I'm not sure the LED you linked too will fit my fog lights. I am using a couple of buckets for 5" Unity Spotlights so the shape matches my spot light and Looks more "vintage", IMO.
They take a 5" PAR 36 bulb which is smaller that the 5.75" that Amazon says your lights are?? Do you have 6" Fog lights?
Old 01-26-2021, 03:56 PM   #16
CarlG
CarlG's Avatar
What I have is are the Unity Fog Lights. They take the same bulb that the '70s 4-light headlight system used, which is 5.75" (GE part # 24460 / 4412A). They are often referred to as 5" lights, even though they are actually 5.75". Pictured below are my lights installed. I can see from your picture that they have a slightly different profile, so maybe the glass replacement fixture I bought won't fit yours.
On a side note, make sure that when you fix the location for your lights that you can still get your tool box open. I had to re-position mine when I discovered that.
Alaskan A's
Old 01-26-2021, 04:26 PM   #17
Y-Blockhead
Ah, I see the 'light'. You have the larger ones, what Unity refers to as F-1 (or similar) series 6". I have the smaller H-1 Series 5".
The replacement fixture is definitely a no go.
Old 01-26-2021, 07:28 PM   #18
Bob-A
Bob-A's Avatar
Smile Re: Fog Light Switch Help
Just for the "purists" the yellow lens fog lights did not come out until 1936.
Bob-A
Bob-A is offline   Reply With Quote
Old 01-26-2021, 09:11 PM   #19
Y-Blockhead
Not sure they had sealed beams bulbs until 1940 or so either... That is what makes CarlG's solution nice. But they won't fit my fog lights
Old 01-27-2021, 07:57 AM   #20
Bob-A
Bob-A's Avatar
Thumbs up Re: Fog Light Switch Help
1940 was the first year for seal beams, however they were called "Glaseal"
bulbs at first.
Bob-A
