01-18-2021, 02:31 PM | #1 |
How to test vintage oil gauge
I just bought an oil gauge on eBay and would like to test it. Does anyone know a convenient way to test these, short of hooking it up to the engine? Seems to have a conventional threaded receiver in the back. I don't have much in the way of hydraulic gear lying around, so something that didn't require major tool investment would be ideal.
I thought about testing it with compressed air, but I thought it might break it. |
01-18-2021, 02:37 PM | #2 |
Re: How to test vintage oil gauge
Possibly a bicycle pump. You would have to be very careful not to “over” pump. Maybe even a hand squeeze pump like I got for my foot boot after ankle surgery.
01-18-2021, 03:46 PM | #3 |
Use water. Head pressure from elevated water is 1psi per 2.31 feet.
If you connect a hose and fill it with water 'till it is 6' 11 3/16" above the gauge it has exactly three psi, middle of the range for your gauge. |
01-18-2021, 03:52 PM | #4 | |
01-18-2021, 04:11 PM | #5 |
Just pull the plug out of the middle right side of the engine between the oil pan and the valve cover and screw the gauge in that hole.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer. |
01-18-2021, 04:20 PM | #6 |
01-18-2021, 05:19 PM | #7 |
No gauge hook-up kits include flow restrictors. After seeing two cars experience Niagara Falls when gauge lines failed I always use them.
You could make your own by solder plugging the first fitting out of the block and drilling a tiny hole. |
01-18-2021, 05:24 PM | #8 |
Stand in front of a mirror, seal your lips around the fitting on the gauge, blow hard while watching the needle in the mirror. You should be able to blow enough to make the needle move, that's all you really need to know.
01-18-2021, 07:20 PM | #9 | |
Sorry, we all need a good laugh during these covid times |
01-18-2021, 08:37 PM | #10 |
Trying to figure out whether Jim is kidding...
Thanks folks, these are all great solutions. I might try them all just to see. This oil gauge was advertised as a Studebaker gauge, but with a 0-6 range and that perfect threaded fitting I couldn't pass it up. Hope it works. |
01-19-2021, 01:03 PM | #11 |
Not kidding, not very scientific either!
01-19-2021, 03:29 PM | #12 |
I have an old hand hydraulic pump that is connected to a T-manifold with a test gauge on one side. I have all sorts of reducer bushings to fit the gauges to be tested and a cap plug to keep the test set clean when I'm not using it. I install the gauge to be tested on the other side of the T-manifold but leave it loose. I then bleed the air out & tighten the gauge to the manifold. I pump the handle to get pressure on the test gauge and compare to the tested unit through several stages. This way I only have to get one gauge calibrated per year and I can test the rest of them for calibration in house.
I use the same set up to test electric gauge indicating systems as well. It passes FAA requirements. I use motor oil for the test set since most of my stuff is for oil pressure. I just have to clean the fuel pressure gauges after testing to prevent any fuel system contamination. Air or nitrogen gas pressure gauges are tested with compressed air and a regulator with a similar T-manifold. It's easier to test them. Gasses compress to a certain degree so I don't mix gaseous pressure gauges with liquid pressure gauges when testing them. For a basic test of any pressure indicator, compressed air works fine but the difference lies in accuracy and concerns for contamination. |
01-20-2021, 12:38 AM | #13 | |
Do not worry about the accuracy. Usually if these gages work at all, they are reasonable accurate. As previously stated, all they really tell you is if the oil pump is working or not. Chris W. |
01-20-2021, 08:30 AM | #14 |
If the oil pump quits, you most likely will hear the engine knocking before you look at the gauge. By the time you look at the gauge, realize you don’t have oil pressure and you shut the engine down the damage will be done. It just takes a few seconds of no oil to ruin a engine. You can’t constantly watch the oil pressure gauge. If the oil pump quits, lack of oil pressure will happen instantly and it will devastating, unlike water pressure that changes gradually and is not normally devastating. If a oil pressure gauge makes you feel good do it.
