Old 01-07-2020, 06:48 PM   #1
wayneyada
Default Ammeter vs volt meter on 12v converted system
This is on a '50 shoebox woodie wagon. It's been converted to 12v but ammeter has been bypassed. Would like to either get it working or change over to volt meter.
So first question, any reason why the ammeter shouldn't work? I know I need to run wire loom backwards from the way it was since it is now neg ground. But otherwise?
Secondly, does anyone make a volt meter conversion or replacement that would fit in the same slot in the speedo cluster - and look somewhat normal?
Thanks in advance for your help.
wayneyada is offline   Reply With Quote
Old 01-07-2020, 07:08 PM   #2
Sid
Sid's Avatar
Default Re: Ammeter vs volt meter on 12v converted system
I prefer a volt meter myself. Ammeters were fine in the day of generators and early alternators. Maybe pushing 45 amp. Today alternators are pushing close to 100 amp or more. Most amp gauges even most heavy duty are at 60 amp. Even semi's and heavy equipment don't run amp meters any more. Also with a volt meter there is generally no power going through it with key off. Some one else may know what will fir your dash. I usually put Stewart Warner under the dash. Just 1 wire to a hot with key on and 1 to ground.
Sid is offline   Reply With Quote
Old 01-07-2020, 07:20 PM   #3
19Fordy
19Fordy's Avatar
Go with a volt meter. Much safer than ammeter if you develop a short.
Under dash fires are terrible.
Old 01-07-2020, 07:22 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
Been using the original induction (loop) ammeter on my 12 volt conversion for a number of years with no issues. (go for it)
Old 01-07-2020, 07:42 PM   #5
34PKUP
34PKUP's Avatar
Trying to understand this. Are you saying that volt meters don't have wires connected to them so they can't short??
34PKUP is offline   Reply With Quote
Old 01-07-2020, 07:51 PM   #6
Sid
Sid's Avatar
Volt meters do have wires. Basically one to + and one to - The loop style gauge just has an induction wire going through a loop.
Old 01-07-2020, 07:54 PM   #7
TJ
TJ's Avatar
I've always used the loop(induction) style ammeters with 12 volts and an alternator. Never had a problem as the wire passes through the loop and is not directly connected to the gauge,
Old 01-07-2020, 09:16 PM   #8
19Fordy
19Fordy's Avatar
No. I just remember a short I had with an ammeter and it burned up my dash wiring. I could be wrong but, I been gun shy of ammeters ever since.
Old 01-07-2020, 09:21 PM   #9
paul2748
paul2748's Avatar
Check with Williamson's in Arkansas - they may be able to take your stock gauge and turn it into a voltmeter and have it look stock.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-07-2020, 09:40 PM   #10
Jack E/NJ
Jack E/NJ's Avatar
19Fordy>>>I just remember a short I had with an ammeter and it burned up my dash wiring. I could be wrong but, I been gun shy of ammeters ever since.>>>
Yep. I'm leery of ammeters too.
Voltmeters only need a very small diameter wire under the dash because they only need to carry a very small current for the voltmeter to operate.
Ammeters (loops or otherwise) need a very large wire because they need to carry very large currents under the dash even with generators.
If a small wire shorts under the dash, it usually melts or pops like a fuse and cuts the connection to the battery and generator.
If a large wire shorts, it usually doesn't melt but acts like a stick welder till there's a fire in full bloom under the dash.
Jack E/NJ
Old 01-08-2020, 07:16 AM   #11
38coop
Can a volt meter be hooked up to any switch or other power supply under the dash as long as there is no power with the switch off,or are there some things to stay away from? I am putting a 12 volt meter on my 49.
38coop is offline   Reply With Quote
Old 01-08-2020, 07:55 AM   #12
Jack E/NJ
Jack E/NJ's Avatar
Yes, voltmeters can be hooked up to just about any supply under the dash. And they use so little current, like a quartz clock, that they really don't have to be switched off. Jack E/NJ
Old 01-08-2020, 08:44 AM   #13
woodiewagon46
Wayne, Jack E, sums it up perfectly in post #10 and #12. Most aftermarket wiring companies won't even supply the wiring for an amp gauge for safety reasons. If it's an antique car that was factory wired for an amp gauge then you don't have much of a choice. If it's a situation where you can rewire your car with a volt gauge, by all means do so. I would give Ron Francis, (a fellow Woodie guy) a call. He sell wiring kits and might have a suggestion.
woodiewagon46 is offline   Reply With Quote
Old 01-08-2020, 08:55 AM   #14
woodiewagon46
Wayne, I probably should have looked for a Ron Francis Wiring catalog before I answered you, but I just found one. There is a 1/3 page article in the catalog explaining why you should never use an amp gauge. As I suggested above, give him a call.
Old 01-08-2020, 09:07 AM   #15
51 MERC-CT
51 MERC-CT's Avatar
If you really need one why not get one to just plug into your cigar lighter?
Old 01-08-2020, 10:06 AM   #16
19Fordy
19Fordy's Avatar
51 MERC-CT: Thanks for posting that voltmeter. Never saw one like that.
Old 01-08-2020, 10:42 AM   #17
Jack E/NJ
Jack E/NJ's Avatar
They consume a bit more power than an analog voltmeter due to the LEDs. So it's best to have them in a switched cigar lighter if you don't pull them out. They also come with a usb port for cellphone, etc charging. Jack E/NJ
Old 01-08-2020, 11:04 AM   #18
5851a
http://www.madelectrical.com/electrical-tech.shtml Thought this was interesting, section on amp gauges he focuses on Dodge but same principle on Ford. Had a Dodge Mini Winni long ago and had to replace harness after meltdown. Every electron passed through the amp gauge, charge and discharge. Was only maybe a number 10 wire, night driving, headlights, wipers, factory AC, cruise, etc. You get a built in campfire under dash.
5851a is offline   Reply With Quote
Old 01-08-2020, 11:02 PM   #19
fordor41
fordor41's Avatar
Yes. Ford. go to a junk yard that has '70's-80's ford trucks with a volt meter. the guts of that voltmeter will fit inside the case for your ammeter. run a line from ign. sw to Vmeter and gnd. and good to go
fordor41 is offline   Reply With Quote
Old 01-09-2020, 01:17 PM   #20
Robz51
Robz51's Avatar
The original induction -style guage on my 52 merc was broken but it had an aftermarket guage under the dash. I was able to remove the faceplate on the original gauge and install it on the aftermarket gauge. It fit in the hole in the cluster and I was able to make metal tabs to hold it in place that utilize the original screw holes.
Works very well.
Rob
Robz51 is offline   Reply With Quote
