08-01-2020, 09:56 AM | #1 |
40 Door Hinge Right Mirror
Anybody know the best source for a door hinge right side mirror these days for a '40?
08-01-2020, 10:23 AM | #2 |
Re: 40 Door Hinge Right Mirror
Phil, If you notice that the LH hinge that is made to accept a hinge mirror has a flat machined on it and a threaded hole for a screw that allows the mirror to move with the door by fixing it to the hinge. Most RH hinges do not have this flat or hole for the lock screw so be advised as you check for mirrors for that side. I suppose an Aussie version of the (RH or for them drivers side) hinge may be the ticket or maybe grinding a flat and drilling and tapping a hole on what you have.
08-01-2020, 10:26 AM | #3 |
Darke, Carpenter list them. You do realize a hinge pin mirror is not correct - yes?
08-01-2020, 10:31 AM | #4 |
Phillip, Most folks report that the RH door hinge mirror gives you a poor, limited view. Plus, as Kube says it's not OEM.
Don't mess with your door hinge if it's working fine right now. Removing hinge pin can easily turn into an unwanted project. JIM |
08-01-2020, 10:44 AM | #5 |
Thanks guys! Great advice!
08-01-2020, 10:45 AM | #6 |
08-01-2020, 11:31 AM | #7 | |
From my limited research of wagons, yes, '40 was the first year they were considered passenger vehicles. Prior to that, they were considered commercial.
08-01-2020, 12:03 PM | #8 |
Kube, actually my car is very late but maybe the hinges sent up to Iron Mountain were first in, last out. Mine is a June car with body # less then 500 from the end. I do know that the drivers side of my car was original, some of the passenger side was missing. Just another oddity that in 1940 nobody cared about.
08-01-2020, 12:39 PM | #9 |
As said any type of passenger side hinge mount mirror is difficult to see or use.
08-01-2020, 12:41 PM | #10 | |
.Mike: It is hard for me to believe that the hinge pin mirror was not correct on the 40 wagon left hand side as they were designed to accept it. As we both know the LH hinge pin mirror is far better for visibility on the SW as compared with the cowl mirror which was introduced for 1940. Right side mirrors both hinge pin and cowl are not very useful. 40larry |
