Old 07-02-2020, 07:13 PM   #1
Brendan1959
Brendan1959's Avatar
Default Piston size
I have picked up a spare motor the piston is stamped Q4Q, do you think that is 40" over?
Brendan1959 is offline   Reply With Quote
Old 07-03-2020, 01:05 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Piston size
It may or may not be.
I know Hudsons in the 30s and 40s and other cars throughout the years had markings on the top of the pistons. Most of the times it is a manufacturing item, like a letter corresponds to piston size. I have only seen a single letter used, but I have not torn too many engines apart. If you could find out the manufacturer of the pistons, they could probably help you in some way. Btw, I checked google and could not find anything for a code like that.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-03-2020, 02:52 AM   #3
dave in australia
It could also be 040, which would indicate .040" oversize. Plenty of engines I've pulled apart have had piston sizes stamped in the top. STD, 020, 040, 060 etc.
dave in australia is offline   Reply With Quote
Old 07-03-2020, 06:50 AM   #4
kenparker
kenparker's Avatar
I agree with Dave in Australia's comment.
kenparker is offline   Reply With Quote
Old 07-03-2020, 07:43 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
Measure the cylinder,s diameter about one inch below the deck. 3.875" + 0.040" = 3.92" is a ballpark estimate of the cylinder's diameter for an 0.040" oversize.
Bob Bidonde
Old 07-03-2020, 09:28 PM   #6
JoeCB
JoeCB's Avatar
Someone had lost their "0" stamp and substituted the nearest thing "Q"
Joe B
JoeCB is offline   Reply With Quote
Old 07-03-2020, 11:41 PM   #7
Brendan1959
The bore measures about 3.913 so that must be 40 over
Old 07-04-2020, 06:17 AM   #8
shew01
shew01's Avatar
Default Piston size
Joe B
Or, maybe eyesight was so bad the installer could not tell the difference between “O” and “Q”?
Old 07-04-2020, 10:02 PM   #9
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Standard bore is 3.875 plus .040 is 3.915
dansluck is offline   Reply With Quote
