Old 05-29-2020, 09:18 AM   #1
Automotive Stud
Automotive Stud's Avatar
Default Throwout bearing replacement
My new release bearing is just a loose bearing, any tips on removing the original from the collar and installing the new one?
Automotive Stud is offline   Reply With Quote
Old 05-29-2020, 10:53 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Throwout bearing replacement
Just to clarify. What year car, engine and transmission are you dealing with? If you're referring to the clutch release throw out bearing,
you need to replace the entire bearing as a unit.
That requires pulling the transmission .
Old 05-29-2020, 11:02 AM   #3
Automotive Stud
It's a 1940 Ford. Obviously it's all apart. What I have is just the bearing, how do I remove the old bearing from the collar? I see speedway sells them as a unit but why spend more money when I already have the parts.
Old 05-29-2020, 11:04 AM   #4
flatheadmurre
flatheadmurre's Avatar
The pressfit ainīt to tough on them usually easy to knock out the old and press on the new.
Old 05-29-2020, 11:09 AM   #5
Tim Ayers
Plus, it's easier to source a US-made bearing vs. having to use the assembled offshore assembly that Speedway sells.
Old 05-29-2020, 11:34 AM   #6
tubman
tubman's Avatar
I have done it a couple of times just using my bench vise. Never had a problem.
Old 05-29-2020, 11:37 AM   #7
Tim Ayers
Tubman,
I need to do this as well. Did you use a socket or piece of pipe as the die and block the back of the bearing to remove it from the hub? Then reverse it to install?
Old 05-29-2020, 11:38 AM   #8
19Fordy
19Fordy's Avatar
I learned something new. Thanks. However, do your best to search and buy an American made bearing.
Old 05-29-2020, 11:40 AM   #9
19Fordy
19Fordy's Avatar
Automotive Stud: This looks promising.
https://www.ebay.com/itm/1928-48-For...%7CMake%3AFord
Old 05-29-2020, 12:42 PM   #10
tubman
tubman's Avatar
Originally Posted by Tim Ayers View Post
Tubman,
I'm sure I did, but it was a couple of years ago so I don't remember exactly. It had to be pretty simple, because if it would have been difficult to any degree, I'm sure I'd remember what I did. One thing I can tell you is that I have a 3/4" drive socket set that gets used more for dies and spacers than it does for nuts and bolts.
I do remember that it didn't take much force at all to move it.
Old 05-29-2020, 01:57 PM   #11
Tim Ayers
Good news is that is from Third Gen Auto and Michael can come on here and tell us about it.
Old 05-29-2020, 01:59 PM   #12
Automotive Stud
Thanks guys, I just wanted to make sure there wasn't any issues I didn't know about. I've read about using a usa bearing. Thanks! Nick
