05-05-2020, 09:57 AM | #1 |
Window Channel
I am working on the slidding window for 39 Woodie. I am not excited about using the material I bought for the vertical strips as they give problems getting the window pull handle into lock position. Has anyone recovered the old vertical channels? If so, what did you use & how did you go about it? Thanks.
05-05-2020, 10:16 AM | #2 |
Re: Window Channel
I am also having the same issue with the vertical channels on my 39. Is there any type of "lube" you can use to make the windows slide up and down easier?
05-05-2020, 12:49 PM | #3 |
Re: Window Channel
