Old 04-11-2020, 08:20 AM   #1
Paul Bennett
Default Water Temp Sensor for Electric Fan
In my new engine I wish to retain the original temperature sensors for the dash gauge. And the passenger side head will have a heater hose emanating from it. So far so good.
I'm wondering where to add the electric fan temp sensor.?. I don't want to use a goofy Y pipe as the sensors will not be in the heads to read properly.
So I am requesting what is normally done to accomodate the added sensor?
Paul Bennett is offline   Reply With Quote
Old 04-11-2020, 09:14 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Water Temp Sensor for Electric Fan
The ones I have used go in the port after removing the drain pitcock.They have an adjustable thermostat for when you wanted it to come on. Parr Automotive is where I got mine.Not sure if that is what you want.
http://www.parrautomotive.com/index....od/prd4029.htm
deuce lover is offline   Reply With Quote
Old 04-11-2020, 09:53 AM   #3
TJ
TJ's Avatar
deuce lover gives a good suggestion. You could also have a radiator shop solder an additional fitting in the tank to accommodate the sensor.
Old 04-11-2020, 10:12 AM   #4
johndee138
johndee138's Avatar
I put my sensor just below the top tank in the radiator. Just pushed it between the tubes. works fine.
johndee138 is offline   Reply With Quote
Old 04-11-2020, 04:20 PM   #5
JSeery
JSeery's Avatar
There are sensors that located on the radiator tubes.
