07-28-2020, 08:39 AM | #41 |
Re: repairing rear axle housing bearing races..
Meric42
I found the pictures and your explanation . Thanks Tony. |
07-28-2020, 10:02 AM | #42 | |
07-28-2020, 11:47 AM | #43 |
Columbia Two Speed has the good races!
07-28-2020, 03:18 PM | #44 | |
07-28-2020, 03:19 PM | #45 |
This is one I did a while back with a full bearing brought of the shelf , The hub race on the axle is a slid fit no machining needed except it needs a sleeve on the OD of the Axle . also a thin sleeve on the ID of the hub ,I have no significant miles on it as yet ,Merc 42 maybe a better way .
07-28-2020, 05:18 PM | #46 |
machine the hub bearing area true, press in a sleeve ,then machine to 80mm Have done two , the roller bearings take WAY more load than a ball bearing, the 2 NU 1010 take a static load of 9500 KGs per side so they will handle 19 tones on the back end . Also the speed of the rollers is way slower than a needle roller. BUT they are costly. I have a set on my bench now so will post some pics, or look up a post I did way back on them . Lawrie |
07-28-2020, 05:24 PM | #47 |
I don't know how to load the old post but is on 04-03-2017, 06:54 AM by Lawrie
07-28-2020, 09:40 PM | #48 |
Here is the link Lawrie.
https://www.fordbarn.com/forum/showt...highlight=axle I have just done the second bearing repair mod for my spare 33 rear end. This fixes the worn bearing area in the hub and on the axle area also. I machined the hub out to 82.5 mm, then shrunk in a sleave, bored that to 80mm.The hub was easy to machine out after I used a new insert on the boring bar. BUT it is very hard. machine the axle OD down to 50mm and press on the bearing inner. The bearings are two roller ones with a total load capacity of 9.6 tons each side and a limiting speed of 9500rpm ,so should be safe there. Only draw back of this, I have to remove the brake drum from the hub to machine it as my lathe is not quite big enough to do it with it on. Lawrie |
