Old 06-26-2016, 05:46 PM   #1
Scott H in Wheaton
Scott H in Wheaton's Avatar
Default 1940 flathead tach drive distributor?
is there such an animal as a distributor with a tach drive that fits a 1940 flathead?
I found a cool looking vintage tach but it looks to be cable driven, not electric.
Am I looking at $$, $$ squared, or $$$ cubed?
Scott H in Wheaton is offline   Reply With Quote
Old 06-26-2016, 05:55 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: 1940 flathead tach drive distributor?
I believe Bubba posted pictures of one conversion last year.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 06-26-2016, 06:12 PM   #3
skidmarks
skidmarks's Avatar
Ran off the crank and Stewart Warner made them. Original intent I think was for industrial stationary motors. I would be a lot of work to make one fit in a 40 ford
skidmarks is offline   Reply With Quote
Old 06-26-2016, 06:18 PM   #4
51504bat
51504bat's Avatar
Williamson's if I remember correctly can convert a cable drive tach to electric. Don't know if the cost would off set the coolness of the tach in question. JMO
Old 06-26-2016, 06:19 PM   #5
Ken/Alabama
Ken/Alabama's Avatar
I think it would be very difficult to do on a 40 with the fan configuration but I wonder if it could be done using the rear plate on the generator like is used on some tractors.
Old 06-26-2016, 06:34 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Bruce
From this link, you can see that these SW rigs don't come cheap, and obviously DO sell!
http://www.fordbarn.com/forum/showth...ner+tach+drive
Here's the very-nicely backyard-engineered distributor that Bubba posted a while back.
T5 W/TORQUE TUBE
One thing you learn from history....is that nobody learns from history!
V8COOPMAN is online now   Reply With Quote
Old 06-26-2016, 07:18 PM   #7
cmbrucew
cmbrucew's Avatar
$1600.00 plus labor for "cool"?
Bruce
Works good
Lasts long time
Old 06-26-2016, 08:41 PM   #8
Cool Kat with Hot Car
Cool Kat with Hot Car's Avatar
SW made a mechanical tach "package" for 39 DeLuxe and 40 Fords with the crank mounted fan. There, of course, is the tach unit itself, with a bracket to mount it to the steering column tube. The cable is driven off of the generator. Straps around the generator hold a rod that in turn hold a clamp that supported the drive in front of the generator. Kind of Rube Goldberg and almost impossible to find a complete assembly today. Much rarer than the normal drive that ran off of the crank nut.
Cool Kat with Hot Car is offline   Reply With Quote
Old 06-26-2016, 08:51 PM   #9
Scott H in Wheaton
Amazing info in such a short amount of time!
I seemed to recall a tractor part as a solution, and then there is the convert-the-tach option. Good to know!
Considering the cost of a 6v positive ground tach maybe this isn't too much of a pipe dream
Old 06-26-2016, 11:22 PM   #10
This is a picture of a complete n.o.s. 39, 40, and i suppose 41 SW generator driven tach assembly. Happy hunting!!
File Type: jpg Screen Shot 2016-06-26 at 9.15.16 PM.jpg (15.3 KB, 75 views)
Old 06-27-2016, 05:24 AM   #11
Charlie ny
Scott,
I did one of these for a customer in Maine except he had a generator
device that triggered his tach..........you could say it was a mechanical drive for an
electronic tach. The casting thickness at the front of the dist housing is very thin
so I chose to epoxy the extension to the housing and then gussetted it. Machining
the female square in end of the rotor shaft was a bit of a challenge but it all worked
out.
Charlie ny
Old 06-27-2016, 05:43 AM   #12
Terry,OH
Terry,OH's Avatar
Scott: A while back someone posted a photo of the 37-41 style distributor with the mechanical Tach. drive molded into the front of the body. They were wondering what it may have come off and there were only guesses such as air compressor or aux generator or air plane. You need a bit of room between the distributor and the radiator to come straight off the distributor.
Old 06-27-2016, 09:01 AM   #13
Uncle Bob
Uncle Bob's Avatar
For those who've never seen one, a couple thousand words worth from my ol' '30 hiboy
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
Old 06-27-2016, 09:09 AM   #14
Scott H in Wheaton
wow, thanks guys!
looks like a tractor generator would be an easier route to take, or modify the tach, or just buy an electric one!
this is what I was looking at:
Old 06-27-2016, 10:30 AM   #15
done4
done4's Avatar
Send a message via Yahoo to done4
Cool gauge, dig the DANGER zone.
Still smokin tires and cigars
done4 is offline   Reply With Quote
