09-13-2018, 09:38 PM | #1 |
Painting a chromed part
Hi Barners,
The rear window surround on the rear convertible top of my 1936 Club Cabriolet is a two piece unit. The exterior section should be chrome plated and the interior portion painted Sand color to match the top irons. Both of mine are chromed and I need to paint the interior piece. I am looking for suggestions on how to prep this piece for paint? Thanks in advance, Bruce/CT
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford |
09-13-2018, 09:58 PM | #2 |
Re: Painting a chromed part
Tape off the good chromed portion to protect it. Then sand blast it very carefully or sand it with 220. Then epoxy primer Then paint it.
09-14-2018, 06:10 AM | #3 |
I would sand blast it with fine grit than couple coats of epoxy primer before putting on your top coat.
09-14-2018, 07:09 AM | #4 |
Another option (and what I probably would do) is to take the inner half to a chrome plating shop and have it chrome stripped. Then prep for paint.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-17-2018 at 05:08 AM. |
09-14-2018, 07:25 AM | #5 | |
What makes you believe your car should have a painted interior window frame?
09-14-2018, 09:40 AM | #6 |
https://www.hemmings.com/classifieds...8/2091984.html Here's another. I would have thought that the inside and outside frame were both chrome plated. https://www.google.com/search?q=1936...GqgqT8zHtroKM: |
09-14-2018, 09:44 AM | #7 | |
Here's da pic! DD |
09-14-2018, 10:26 AM | #8 |
V8COOPMAN,
Through 1935 and well in to 1936, the inside frames were in fact chrome plated. I don't have access to exactly when the change to painted (inside) came about in 1936, other than "late" per the Early Ford V8 Club's restoration manual.
09-14-2018, 07:56 PM | #9 |
Hey Kube...I was NOT offering an opinion. I was just making that picture easier to view. DD
09-15-2018, 06:53 AM | #10 |
who cares its your car do it your way and enjoy it as for painting chrome make sure it solid and sound clean thoroughly tape off and use a good quality etch primer
09-15-2018, 06:10 PM | #11 |
>>>Both of mine are chromed and I need to paint the interior piece.>>>
Need? Jack E/NJ |
09-16-2018, 10:20 PM | #12 |
Jack E/NJ,
When I composed this question I didn't realize that it was going to be checked so closely for word content. My writing has rarely been reviewed since high school - 50 years ago plus 8 years of additional schooling. I guess NEED was a little strong. It is my go-to phrase. I might have better used something like WANT or DESIRE. Please accept my sincerest apology. Bruce/CT
09-17-2018, 06:55 AM | #13 | |
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
