Old 01-03-2011, 05:28 PM   #1
Kirby1374
Kirby1374's Avatar
Default how tight?
after getting something too tight and breaking it I am asking the brains. I am replacing the rubber in the stock A rear motormounts and also the front with an original style 3 spring and plate setup. How tight? Just so I can put the cotter pin in? I don't want to squeeze out the rubber on the rears.
wudda u tink?
Kirby1374 is offline   Reply With Quote
Old 01-03-2011, 05:35 PM   #2
Rich in Tucson
Rich in Tucson's Avatar
Default Re: how tight?
Iffen you have all of the right parts, including the tubular spacers that fit within the holes on the outside of the bolts, you cannot overtighten them-the spacers do just that - they limit how far down the nut can travel on the bolt and by so doing create a gap for the rubber pad.
Rich in Tucson is offline   Reply With Quote
Old 01-03-2011, 05:38 PM   #3
Rich in Tucson
Oops forgot the front - tighten down until the hand crank functions as it should in engaging the crank pulley. You might find that the hole drilled for the cotter pin on a repro bracket is far off from where your nut ends up.
Old 01-03-2011, 05:38 PM   #4
Kirby1374
Kirby1374's Avatar
Thanks, I bought the hardware kit; bolts, spacer tubes, nuts and cotters. So I will cinch'er down!
Old 01-03-2011, 05:40 PM   #5
Kirby1374
Kirby1374's Avatar
thanks as well, I am using an original bracket just new mount kit for the front. Mine had the 2 springs hooked together with the rubber inserts previous.
Old 01-03-2011, 06:07 PM   #6
Jim Parker Toronto
Jim Parker Toronto's Avatar
Just put my new ones in last week with the help of my 6 year old grandson, he had his side done before me! Great kid, he's gonna own that car one day, so he might as well help build it..... P.S., he loved putting in the cotter pins....
Jim Parker Toronto is offline   Reply With Quote
Old 01-03-2011, 06:42 PM   #7
Bruce of MN
Bruce of MN's Avatar
He'll remember it the rest of his life, too.
Old 01-04-2011, 02:34 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
Remember to get the front lined up where it should be first, then make the rears tight and install the cotters.
Old 01-04-2011, 01:52 PM   #9
jimnungesser
jimnungesser's Avatar
Send a message via AIM to jimnungesser
Good advice!!
Jim, 31 sw town sedan
jimnungesser is offline   Reply With Quote
